found work around for compound assembly issues, #42400
Reference: blender/blender#42400
when assembling a compound body inside a function the objects physics bound was incorrect, also the objects physics bound (child) was left where the object was when assembled,
a work around was to do
(calculations for assembling)
assembling function (center of mass etc)
function(create mesh libNew and parent children and assign mass of "centroid")
for all parts in assembly
removeParent()
disableRigidBody()
suspendPhysics()
setParent(centroid libNew host)
however after doing this, once the object is removed from the assembly with "removeParent" it still had the complex compound shape bounds in physics,
so
for removed objects:
add new copy of object
set properties
end old object
works around all issues.
Added subscriber: @JacobMerrill-1
https://www.youtube.com/watch?v=EZFewOI_nCY
working assembly system in game
Added subscriber: @mont29
I can’t I understand what’s the issue nor topic really here… is it about GE? Blender itself? Is it a bug report? something else?
Please follow our submission template and instructions, it really helps sorting things out…
There was a bug in the game engine, "ending object crashes game engine" that was related to ending the child of a compound object,
another bug, related to this was about the shape bounds not moving when a object was assembled (it left the physics bound of the child where it was when parented)
I found workarounds for both of these issues,
ending compound object child not crashing game
object.removeParent()
object.disableRigidBody()
object.suspendDynamics()
object.endObject()
as for the shape bounds,
I did a similar thing
for objects in new assembly:
object['Root']=parent
object.setParent(object['Root'],1,0)
so, this updated bullets shape bounds on the compound object right after assembly.....
basically I found my own problem and it was related to rigid body assembly, incorrect shape bounds, "ghosts" of objects physics bounds,
and when a object was disassembled it would have "ghosts" in it's physics bounds....
issues I found and worked around
1.in physics visualization shape bound was not correct for my rigid body assemblies
if you ended a child of a compound shape/rigid body it crashed the engine
if you removed a compound assembly object it carried with it "junk" (it could not be moved but could rotate....)
solutions
1 = reparented same objects after disabling rigid body and dynamics (after initial assembly)
2 = remove parent remove rigid body remove dynamics then remove object
3= add in new copy of component , copy properties from old object - end old object
Thanks for the clarifications.
Added subscriber: @JorgeBernalMartinez
Jacob, we need blends for the both issues that you commented. This way we can check the possible bugs.
thanks.
ok
File
Assemblysimplified(1) {F179643}= Problem (press P, then press space) see the floating white cube?)
AssemblySimplified2 = work around
turns out it has to do with applyMovment + setParent in the same frame.
setParent then apply movement does not update the physics of the child shape bound.
(I lost most of my old files so I don't know if the other problems I ran into were user error or?)
AssemblieSimplified2.blend
https://youtu.be/fpS9mygynRk
video of exposing the undesired activity,
and the work around,
1 when a object is compound parented, if it is moved after parenting, it leaves the physics mesh, and only moves the graphics mesh.
2 If applyMovement is done, in a frame before parenting, the movment never happens (at least in this case)
a work around for number 2 = use object.worldPosition, and get the world vector you need for local movment using
desired=object.worldPosition+(object.worldOrientation*Vector([x,y,z]))
Closed as duplicate of #40427
