Volumetric Material appears wrong in Rendered Viewport Shading #42409
Reference: blender/blender#42409
Win 7 64bit, Radeon HD 6850
tested in 2.72a & 2.72b
Volumetric Material appears wrong in Rendered Viewport Shading when World Background is black (0,0,0)
Probably the World Background need to be black to reproduce this bug.
Possibly also a scene with black World Background Color must be saved as default startup file in advance.
Switch to Cycles Render Engine
Delete the default Cube and Lamp.
Add a UV Sphere, unwrapp it, add Diffuse Material, add UV mapped Image Texture to the Diffuse Color Input, set the Object to be Shaded Smooth.
Add an Ico Shere to same position as the UV Sphere is, scale the Ico Sphere slightly larger than the UV Sphere is, add a Volumetric Scatter Material, set the Ico to Shaded Smooth.
Add a Sun Lamp, turn Multiple Importance Sample on.
Switch the Viewport Shading to Rendered.
If the Volumetric Scatter Material appears wrong now somehow (like in the attachement / lower left image) go to the World Buttons
and change the Background Color to any brighter than black(0,0,0). If the Material appears correctly now it should stay like this even
if you change the Background Color to black again.
Greetings Martin
Added subscriber: @martinme
Added subscriber: @FloridaJo
Can you attach a blend file of when it appears wrong?
I can't reproduce on OS X.
It's a mystery !
I can't find a reliable way to reproduce this bug by myself now.
I was able to reproduce it once again now, but when I just moved the Render Camera it disappeared / rendered correctly.
I tried to reproduce it serveral times afterwards but failed.
I had this bug the first time 2 days ago and then it was also hard to reproduce. For sure it is not reproducable within
the same Blender session, when it ones rendered correctly before. Possible I also may need to restart my PC - but I just don't tried that.
I may try it again in the next days. For now I'm a bit unstrung and tired. ;)
Added subscriber: @mont29
Well, without a way to reproduce it, or at least a .blend file showing the bug, we can’t do much.
No blend file, no way to check..
