Problem for select/deselect multiple vertices with API Python #42467
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#42467
Ubuntu 14.04
Nvidia 8600 gt
Broken: 2.72 88cc1a7
Does not work to select and deselect multiple vertices via a script
Added subscriber: @jefrau
error.blend
Thanks for the report, but there is no bug here. Setting selection in Object mode is not a best idea, because it only set given element's select status. However, selecting two vertices can have the side effect of selecting an edge (which happens in your case), but those relations are only handled in Edit mode.
So what happens for you is that you select two vertices. When you switch to Edit mode, their common edge is selected as well. Then back in Object mode you deselect the vertices, but not the edge, so once you go in Edit mode again, those vertices get automatically re-selected.
