Curve modifiers not respected by other objects/cannot be applied correctly #42680
Reference: blender/blender#42680
Win 7 x64
Broken in 1103abd
Using a shrinkwrap modifier on a curve gives the correct result in preview, but cannot be applied, and other objects relying on the curve shape use the original shape instead. Not sure if this is a failing of the modifier or just the intended behavior, but if it is intended, the modifier probably shouldn't be an option at all.
http://pasteall.org/blend/32987
View curve modifier and behavior of object plane.001
Added subscriber: @MatthewHeimlich
Added subscriber: @mont29
Please always attach files here, pasteall is rather volatile storage… curveerror.blend
Sergey, think this one is for you?
The thing here is, the modifier is applied on the tessellated curve, not to the curve's CVs. This makes final result of the curve looks fine. But Curve modifier uses curve path (which is pre-tessellated spline), which gives unexpected result for you.
You can make it so shrinkwrap is applied on the CVs instead, but for that to work reliably you'll probably need to subdivide the spline couple of times to have result you're expecting here.
Thanks for the report, but it's just difference on whether modifier is applied on pre or post tesselated spline, which si totally intentional here,
