Baking an object's texture is effected by the 'Exclude' option for the first render layer in the Render Layers menu.
Mac OS 10.10.1 - GTX580 - GTX560Ti
Broken: 2.72b 9e963ae
Worked: ?
Baking an object's texture is effected by the 'Exclude' option for the first render layer in the Render Layers menu. If the object being baked is on a layer that's being excluded, the resulting baked texture will be black.
  • Unwrap default cube
  • Add material to cube
  • Create new image
  • Add image to cube material and have it selected in the node editor
  • Move the cube and light to layer 2
  • In the Render Layers menu, set 'Exclude' to 'on' for layer 2
  • Add another Render Layer, making sure that 2 is on for it.
  • Disable Render Layer 1
  • Select the cube
  • Click 'Bake'
  • The baking always takes the exclusion of Render Layer 1 into account when baking the texture.
I don't think the exclude options should have any effect on texture baking, let alone have an effect when the render layer has been disabled.
Here's a screencast of the bug:
http://www.spintheyarn.co.uk/projects/baking-bug.mov
Julian Eisel (Severin) lowered the priority of this task from 90 to 30.Nov 24 2014, 5:48 PM
Hey @stephen thomas (stephenthomas0),
could you also append a .blend file, so we can easily reproduce the bug? This would help us to help you ;)
Sure, here you go:
Just hit bake and you should get a nice black texture (which should be red & blue). Turning off the 'Exclude' for layer 2 on Render Layer 1 will make it work again...
Mhh, I get a crash when pressing bake. I don't know the code base but maybe the issues have the same root.
@Dalai Felinto (dfelinto), got a failed kernel_assert. Error log:
/blender/intern/cycles/kernel/kernel_compat_cpu.h:51: T ccl::texture<T>::fetch(int) [with T = ccl::float4]: Assertion `index >= 0 && index < width' failed.
Julian Eisel (Severin) raised the priority of this task from 30 to Normal.Nov 24 2014, 6:21 PM
Yes, I got a crash when I tried to bake on the CPU, but GPU seems to work fine. Maybe the issues are related?
When I say "Seems to work fine", I mean that the bug I originally raised still happens, but Blender doesn't crash on the GPU when you try to bake.
@Julian Eisel (Severin) I believe this is a duplicate of T40709 (which is in our todo list).
Now the crash would be something new. I'll see if I get that as well.
The crash only happens when there are zero objects in a (to be rendered) layer. It is still a bug (related to the T40709) but not something you would run into in a real production.
I ran into it on a real production, it's how I found it...
@Dalai Felinto (dfelinto), any chance you have some time left to look deeper into this? I could also do, shouldn't be a big challenge code-wise...
Oh, and just to be clear, we're talking about the crash, the original bug report is a duplicate
Okay had another quick look, printing out index and width shows that width stays 0 while index is > 0.
Mind investigating this @Dalai Felinto (dfelinto)? (Or maybe @Sergey Sharybin (sergey) is interested?)
Dalai Felinto (dfelinto) changed the task status from Unknown Status to Resolved.Mar 2 2017, 10:13 AM
This was fixed by rBefe78d82 - it now prevents baking from happening in those cases.
