.3ds-Exporter: Export Empties as 3DS Point Helper
Confirmed, NormalPublicTO DO
Windows 7
2.70a
Empties do not get exported as 3DS Point Helpers when using the 3ds exporter
Edit the default cube and add an Empty object that should be converted to a 3DS Point Helper when the file is opened in 3DS Max, but instead the Empty object data are lost and not converted to a 3DS Point Helper (i.e. the equivalent of Blender Empties objects.
L. V. (lvignals) raised the priority of this task from to 90.
L. V. (lvignals) updated the task description. (Show Details)
L. V. (lvignals) edited a custom field.
L. V. (lvignals) added a subscriber: L. V. (lvignals).
Hey @L. V. (lvignals),
What you report here isn't a bug, I'd rather consider it as a ToDO. Also, please make sure to use a proper title for the next time you report a bug. SWE isn't really descriptive.
Nevertheless, thanks for the report!
Julian Eisel (Severin) renamed this task from SWE to .3ds-Exporter: Export Empties as 3DS Point Helper.Nov 24 2014, 6:43 PM
Julian Eisel (Severin) removed Julian Eisel (Severin) as the assignee of this task.
Julian Eisel (Severin) lowered the priority of this task from 90 to Normal.
Julian Eisel (Severin) edited a custom field.
