3D texture painting not working correctly
Closed, InvalidPublic
Windows 7 x64, ATI Mobility Radeon HD 5470
Broken: 7.72b
Worked: 2.71
3D paint mode will only paint to the first texture in the list of textures. I'm using Blender Internal renderer so that I can use GLSL for live bump map painting. If the color is in the first slot then 3D paint will only paint to that texture and going into edit mode to select the other texture as active will be ignored.
Create a cube, unwrap, add a material and add two image textures to the material. Create two images for the textures.Go into edit mode and select the first image as active for painting. It should paint normally. Go back into edit mode and select the second image for painting. It will now paint to the first texture image instead..
tex1 - color
tex2 - bump
If I go into edit mode and select the color texture as active and go back to object paint it paints the color map.
If I go into edit mode and select the bump texture as active and go back to object paint it paint the color map.
Adrian Ferguson (hellfireboy) raised the priority of this task from to Needs Triage by Developer.
Adrian Ferguson (hellfireboy) updated the task description. (Show Details)
Hi,
Blender 2.72 has a new system in place to select textures and UVs in texture painting - going to edit mode is no longer necessary. Please read the release notes for texture painting in 2.72:
http://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.72/Painting
