Rename a file (tracking library links)
If you rename a file and its used as a library,
BAM should be able to update any blend file which point to it.
notes:
  • We may need a special command to rename - so we can keep track of this when committing.
Campbell Barton (campbellbarton) changed Type from Bug to To Do.
Campbell Barton (campbellbarton) raised the priority of this task from to Needs Triage by Developer.
Campbell Barton (campbellbarton) triaged this task as Normal priority.
Sybren A. Stüvel (sybren) closed this task as Archived.
Sybren A. Stüvel (sybren) claimed this task.
Superseeded by BAT🦇
BAM has been superseded by Blender Asset Tracer (BAT). BAT supports many of the features of BAM, and is actively being developed. All open tasks regarding BAM are closed, and the project will be set to read-only. If you use BAM in your own project, please consider migrating to BAT.
