bsurface broken in local view #42805
Closed
opened 2014-12-05 02:12:25 +01:00 by jordi torres · 10 comments
2.72b 9e963ae
when enter in edit mode of an object, then in local view ( and this is important because if not the bug doesn't happens) add a greace pencil trace an try to make a bsurfaces it brokens.
**System Information** Operating system and graphics card **Blender Version** 2.72b 9e963ae **Short description of error** when enter in edit mode of an object, then in local view ( and this is important because if not the bug doesn't happens) add a greace pencil trace an try to make a bsurfaces it brokens. **Exact steps for others to reproduce the error** Based on a (as simple as possible) attached .blend file with minimum amount of steps
Author
Author
Added subscriber: @jorditorres
Added subscriber: @mont29
Please always add a file demonstrating the issue.
Bastien Montagne self-assigned this 2014-12-12 09:33:58 +01:00
No news in one week…
Author
crash.blend
Sorry for the delay. The bug is too easy to reproduce:
just enter to edit mode of any object you want, go to local view of this object, draw some grease pencil lines and try to add a bsurface. a message like this appears:
[crash.blend](https://archive.blender.org/developer/F131001/crash.blend) Sorry for the delay. The bug is too easy to reproduce: just enter to edit mode of any object you want, go to local view of this object, draw some grease pencil lines and try to add a bsurface. a message like this appears: ![Captura_de_pantalla_2014-12-12_a_les_7.32.01.png](https://archive.blender.org/developer/F131003/Captura_de_pantalla_2014-12-12_a_les_7.32.01.png)
Bastien Montagne removed their assignment 2014-12-12 11:51:26 +01:00
Brendon Murphy was assigned by Bastien Montagne 2014-12-12 11:51:26 +01:00
Brendon, you know that addon iirc? can you check the report? Thanks.
Member
Closed as duplicate of #39664
Reference: blender/blender-addons#42805
