Separate and Combine HSV distorts the hue value #42888
5 Participants
Reference: blender/blender#42888
Tried on more than one platform
Broken: 2.72.3
83cbcef
and latest official 2.72bShort description of error
Plugging the hue value into a color socket changes the value slightly.
Both from the Separate and the Combine nodes..
Add two objects with emission nodes, the color node of one is connected to a combine HSV node with the values 0.75,1,1
while the other has the color set to the same values..
after a render one will notice a clear color difference. The combine HSV gives a hue value of 0.7892 instead of the 0.75 without..
Added subscriber: @HenrikOhlin
Added subscriber: @FloridaJo
True. It appears by using OSX color picker, that a value of .7 for hue gives a closer color than .75.
This issue was referenced by
1549fea999
Closed by commit
1549fea999
.This issue was referenced by blender/cycles@da96c9dd48
Added subscriber: @MaiLavelle
Sergey, doesn't that just reinforce the incorrect behavior from #41287? The discrepancy between the HSV combine node and the color picker is caused by the incorrect behavior of the color picker, not from the HSV nodes. This likely needs more discussion, can this change at least wait until after the 2.73 release? This isn't a minor change and could cause drastic visual differences of existing shaders.
Added subscriber: @Sergey
Yes and no. HSV does make no sense if the input color is in linear space and it wouldn't give you the same result as if you'll try to, say, bump saturation in gimp making control over the values totally unclear.
Sergey, would you please give this a closer look?
While it is slightly confusing to have, say, Blender and GIMP behave differently, this is a result of the differing workflows of these programs... GIMP and other photo manipulation type software tend to go for a perceptual workflow so an artist can see directly what an image on a webpage or a print for instance will look like. Blender and other rendering software on the other hand have a linear workflow (you know all this...) Having such a workflow allows for physically based results as well as the ability to use real world measurements for input... unfortunately this means that, unlike the perceptual workflow, an artist can't directly see what result they will get. This is the nature of rendering software, and is why Cycles real time preview is so important. An artist can only really see what a color will look like after its been rendered.
It's also important to note that HSV is not a perceptual model, even though it sounds like it should be. (It's only defined in terms of primaries, without regard to how the visual system responds to those primaries, or what color space the primaries are in.)
To be sure of all of this I did some tests, the results of which are below. Each image is a careful recreation of the same scene, using the appropriate method for HSV input in each program... (HSV is 270 degrees from red, 100% saturation and value; background is 5% full intensity)
First thing of interest when I was putting this together is the surprising number of HSV nodes in Blender... theres a lot of them, only a select few are displayed here, but the results are consistent
Second, while the changeset introduced causes the Cycles HSV combine node to produce the same color as GIMP, this is quite a difference from the other nodes in Blender, as well as being divergent from other rendering software. It is also slightly meaningless to match GIMP here, for the reasons noted above.
The background in the image from GIMP is darker than all the others. This is due to the sRGB workflow. The two colors (disk and background) are, however, the same as all the others relative to the colorspace. The 2.73rc1 HSV combine result is inconsistent with everything else.
I'm concerned about the impact this change will have on Blender and the artists that use it. The inconsistency is confusing, previous node tress will behave in unexpected ways, and hardcoding a color transform into a node limits that nodes usefulness. Allowing artists to manually and explicitly choose what colorspace to use allows for greater versatilely and accommodates more workflows. This would also likely be easier to maintain.
Please consider reverting this changeset.
So as not to leave anyone with out a solution should anyone want to use HSV based on different colorspaces, I've included a blend file with two node groups that preform linear/sRGB conversions. (It'd be great to have such nodes as part of Cycles in the future...)
Thank you for all your hard work!
maiself_-_color_transforms.blend
c5927cd977
This issue was referenced by blender/cycles@78b4d7b962
b0dc79c14b
