Rewrite/Improve Boolean Modifier Page #42896
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
7 Participants
Reference: blender/blender-manual#42896
The current Boolean modifier documentation http://www.blender.org/manual/modeling/modifiers/generate/booleans.html contains lots of unnecessary text and Capitalized words. A lot of it is old and incorrect information, and also contains barely-related info (such as how to recalculate normals).
Therefore I think the easiest solution is to rewrite the page completely, including only information relevant to the modifier.
Added subscriber: @GregZaal
I'll take a stab at cleaning this up.
Added subscriber: @JohannesThomasMeyer
Is it possible to include the (imho) very important hint, that a Mesh has to be non-manifold to get reliable results being used with the Boolean Modifier? I had lots of time wasted to figure this out and tried all kind of solutions which didn't work until I finally found it somewhere hidden in the blenderartists forum.
Of course it would be even better to give a hint in the UI when having a Boolean Modifier including a non-manifold mesh. But having it in the documentation is a first step to help others ;-)
Added subscriber: @ideasman42
@JohannesThomasMeyer, yes, it should.
Added subscriber: @gandalf3
Is this still being worked on? If not I would be willing to step in
This issue was referenced by 928
This issue was referenced by 932
Added subscriber: @ChrisHoppe
This issue was referenced by 3573
