Sun lamp shadows broken in GLSL view #42917
Reference: blender/blender#42917
Win 7 64bit
Mobility radeon 5650
Catalyst driver 12.10
Broken: blender-2.73-testbuild1-win64
Worked: Official 2.72b
Sun shadows in GLSL view do not look right. It appears the whole of the shadow map frustrum is filled with the shaded value. I'm attaching a comparison screenshots from the viewport. The bug happens with simple and variance shadow map style.
I do have older drivers, but everything worked well so far. If other cards work properly I could test with a newer driver version.
Added subscriber: @lamoot
Added subscriber: @Psy-Fi
Test file or it didn't happen.
Just a note here, we had an issue there but was fixed 1-2 weeks ago. If this is happening on latest builds from builder.blender.org we really need a test file to reproduce.
I'm attaching a test file and a screenshot of how it looks like on my computer. It happens with a very simple setup already, default cube, plane and a sun lamp with shadows enabled.
I tested the file in the following blender versions with the same result.
blender-2.72-7234153-win64
{F132289}
Cannot confirm here... Smelling a driver issue, or something Windows related
Cannot confirm here either I'm afraid. Can you try with factory settings? Also, can you attach a system_info.txt file generated from blender (see http://blender.org/manual/vitals/help.html#diagnostics-options)?
Factory settings give the same result. I'm attaching the system_info file.
system-info.txt
I'll see if I can test this on another OS tomorrow. Or if possible get the latest drivers installed (tricky due to manufacturer limiting which drivers can be installed).
Alright, I can confirm on the MacOS trashcan I'll see if I can fix this
Ok, I tested blender-2.72-7234153-linux-glibc211-x86_64 on Linux Mint 17 with default open source drivers and everything displays fine. It appears the issue is indeed with windows/driver.
This issue was referenced by
3e61478b1b
Closed by commit
3e61478b1b
.It was a real issue after all, it's just that NVIDIA is often much more forgiving in OpenGL use. Thanks for the report!
I tested with the latest build from buildbot and the issue is gone here as well. Thank you for the fix.
