Unsaved baked image cannot be used in node editors.
Win8.1 64bit | GTX680
Broken: 2.72.2 409043c
When trying to use the baked image within Blender, say, using it in Node editor, it just turns back to the initial look.
  1. Create a blank image;
  2. Bake the default cube using this image;
  3. After baking, try using it in Node editor.
PS: Perhaps similar issue to this one? https://developer.blender.org/T42008 FYI. Thanks.
Leon Cheung (leon_cheung) updated the task description. (Show Details)
Leon Cheung (leon_cheung) raised the priority of this task from to Needs Triage by Developer.
Leon Cheung (leon_cheung) set Type to Bug.
I can't reproduce this. Please attach a test file, this could well depend on specifics such as which node type you use, which render engine etc.
Have you tried this with a recent build from https://builder.blender.org ? Although i can't reproduce it with 2.72 either ...
I don't think a test file would help, because if I make a test file, the image has to be saved, but the problem only occurs for UNSAVED image... I think I may try to make a screencast to show it better. asap.
Julian Eisel (Severin) triaged this task as Confirmed, Medium priority.Dec 18 2014, 2:18 PM
Mhh, seems to me the issue appears after using drag & drop. Looks like it's using the original image which causes the generated one to be overwritten :/
This issue is very similar to other issues such as T41598 or T41762. Basically any operation that clears the caches of an image will cause regeneration from a file or in the case of a generated image, flood filling with the generated value.
I do have a patch that explicitly creates a file when we generate an image instead, but it might be a bit of a controversial change.
@Antony Riakiotakis (psy-fi), why not save it in /temp/ by default?
Anyway, not sure if it's worth having two reports open that have the same root (event though the symptom is different)?
@Antony Riakiotakis (psy-fi), i'm not really a fan of that patch. The existing pipeline is to be revisited and cleaned up where needed. The patch just adds extra confusion.
