Grease Pencil Ctrl z bug #42961
7 Participants
Reference: blender/blender#42961
Ubuntu 14.04, Intel onboard card
Blender Version 2.73 official test build
Reproduceable: YES
Crash of Blender:NO
when drawing with grease pencil and you press CTRL+z the frame changes to the last frame you used. Should stay on the frame you are working on.
draw on frame 1, change the frame to for example 10, draw again, press CTRL+z, it goes back to frame 1.
Added subscriber: @ivampretti
This issue was referenced by
071ec918f4
Closed by commit
071ec918f4
.Changed status from 'Resolved' to: 'Open'
eekk copied wrong task number, should be blender/blender-addons#42895... So this is still open
Added subscriber: @pollend
Removed subscriber: @pollend
Added subscriber: @Sergey
Joshua, do you mind having a look here?
Added subscriber: @JoshuaLeung
Added subscriber: @zeauro
ubuntu 14.04 64bits NVIDIA Titan Black
hash:
cefb764
I cannot reproduce.
Ctrl Z does not change frame for me.
@zeauro, yeah it only happens when using the arrow keys
I have a fix ready for this, but would like to check with @JoshuaLeung before committing
Indeed, this seems to be something that only happens when using the arrow keys and not when dragging the time slider. In that case, it's not a bug, but rather, something done by design (or rather, as a compromise). See
8621c71c4c
The rationale for this is something like this:
There is no way to tell the difference between an operator being called multiple times as the key was held down or pummelled rapidly, vs the operator was purposefully executed to yield an undoable reference point/state. At least not within the event handling system we have in place.
Admittedly, it is not the most ideal situation, and some cases like this still happen. But as the "simplest" solution, this is not that bad either.
EDIT: Now, if we really did have to make the arrow keys case also work, we'd have to resort to doing crazy things like making the screen.frame_offset operator modal. Its event flow would look something like:
Now, doing something like this is probably overkill, but is something we could consider if it really was that much of an issue (which I don't think it is).
Closing. Not a bug.
@JoshuaLeung, I agree, that's why I wanted to check with you before committing...
I think your proposal would be fine, but I'd rather call the frame change from modal(), as animators might want to search a specific frame or want to slowly scrub through the frames, one by one.
Without implementing your proposal, I'm afraid we'd get more reports on that, so I think it would be worth investigating
I just think that if you draw and made a mistake, you should be able to press Ctrl+Z and undo only the thing you draw even moving the timeline with the arrow keys. Because its more precise move frame by frame with the arrow keys than an slider. And most of the time we just move about 2 or 3 frames, not 50. And every time its moved to a frame to draw again you should move to the same frame again its a waste of time.
