Custom Frame Rate Does not allow some Common Frame Rates #43006
2 Participants
Reference: blender/blender#43006
Windows 8.0 Intel HD 4600
Broken: (Blender 2.73RC)
Worked: (Unknown)
Custom Frame Rate Does not allow some Common Frame Rates. For example 60000/1001 which is needed for the DNxHD Codec
Added subscriber: @Blendify
This isn't a blender bug, it's just some codecs in combination with containers and other settings are not supported by FFmpeg. We're doing our best to provide reasonable description of the error provided by FFmpeg and in this case it doesn't work very well. You can see full error message from FFmpeg in the console when running blender with --debug-ffmpeg command line argument.
It is in our todo to simplify codecs selection, but it's not so trivial at all, especially since FFmpeg does not provide any information about what is supported and what is not before you actually starting to encode.
Thanks for the report anyway.
Can't this be fixed by changing the limit of values for the frame rate
No, because some codecs also requires specific values of frame dimensions.
But we have customs frames dimensions
Wait, must have misunderstood your previous comment then. What exactly did you mean?
The reason we can't render in this codec is because it requires a custom frame rate which exceeds the value limits. So if the value limits are changed the codec should work.
Alright so a just realized that there is a way to get around this. Under presets there are some options one of them being the frame rate needed for this codec. However it would be better for the design if you could choose this manually also.
Every single value which is controlled by the preset is controllable manually as well.
Added subscriber: @Sergey
@Sergey I realized that and it uses 60/ 1.001 which is different then the error message. So is it possible to change the error message?
As said in the very first comment, the error messages are being generated by FFmpeg we only trying to do out best in displaying them.
Aliright thanks I guess this can be more of a todo then
