100% proxy is not used
Win7x64 GTX660M
Broken: 2.73rc
Building 100% proxy in vse works fine but its never used.
btw. proxy building for meta strips is not working correctly (artifacts) - should be disabled or fixed
1 Make some example vse edit (easiest to see the bug is with some havy render scene strip)
2 enable and build proxies for strip 50% and 100% (remember to set custom dir)
3 switch vse preview proxy render size to 50%
4 you can scrub - it works
5 switch vse preview proxy render size to 100%
6 the scene is rendered on the fly - no proxy is used
Czarek Kopias (kopias) raised the priority of this task from to Needs Triage by Developer.
Czarek Kopias (kopias) updated the task description. (Show Details)
Czarek Kopias (kopias) set Type to Bug.
