Blender has stopped working - windows error message on startup. #43115
Closed
opened 2015-01-03 23:31:30 +01:00 by Peter · 31 comments
Asus Maximus VI Formula
MSI Twinfrozr IV 4GB GTX 770 SLI (6040x1080 + 1920x1200)
Intel Core i7 4770k, (Overclocked) 1.25v, 4.4GHZ, Intel Turbo enabled, hyperthreading enabled. 900MHZ OC
16GB 2133MHZ Corsair Vengeance PRO
XFX ProSeries Black Edition - 1050W PSU
Samsung 840 EVO 250GB x2 (RAID 0) 142 GB avaliable 64KB stripe size
Seagate barracude 2TB 7200 RPM as backup and storage 1,17TB remaining
Windows 7 ULTIMATE 64-bit
Temperatures are not an issue.
  • Processor does not exceed 54C at 100% load 99% cache usage.
  • GPU 1 80C 100% load.
  • GPU 2 70C 100% load
Version
Broken: 2.72b (x64)
Worked: all the versions i have tried haven't worked.
Concurrent issue:
after installing the application, I attempt to start the program by double clicking the desktop icon it creates. upon starting Blender.exe crashes, giving the following error message:
Windows can check online for a solution to the problem.
  • Check online for a solution and close the program. (Didn't work)
  • Close the program
Additional Information: >
Problem signature:
Problem Event Name:	APPCRASH
Application Name:	blender-app.exe
Application Version:	2.7.2.0
Application Timestamp:	5446569e
Fault Module Name:	MSVCR120.dll
Fault Module Version:	12.0.21005.1
Fault Module Timestamp:	524f83ff
Exception Code:	c000001d
Exception Offset:	0000000000092bc3
OS Version:	6.1.7600.2.0.0.256.1
Locale ID:	1030
Additional Information 1:	9c5b
Additional Information 2:	9c5b99d1538af1465d6588ee6e30c6d2
Additional Information 3:	ffa6
Additional Information 4:	ffa6c829f7fac5222bb75dc93477b4fc  **
I don't know what causes the error, all i know s what the application tells me, as listed above.
**System Information** Asus Maximus VI Formula MSI Twinfrozr IV 4GB GTX 770 SLI (6040x1080 + 1920x1200) Intel Core i7 4770k, (Overclocked) 1.25v, 4.4GHZ, Intel Turbo enabled, hyperthreading enabled. 900MHZ OC 16GB 2133MHZ Corsair Vengeance PRO XFX ProSeries Black Edition - 1050W PSU Samsung 840 EVO 250GB x2 (RAID 0) 142 GB avaliable 64KB stripe size Seagate barracude 2TB 7200 RPM as backup and storage 1,17TB remaining Windows 7 ULTIMATE 64-bit Temperatures are not an issue. - Processor does not exceed 54C at 100% load 99% cache usage. - GPU 1 80C 100% load. - GPU 2 70C 100% load Version Broken: 2.72b (x64) Worked: all the versions i have tried haven't worked. Concurrent issue: after installing the application, I attempt to start the program by double clicking the desktop icon it creates. [upon starting Blender.exe crashes, giving the following error message: ](http://i.imgur.com/7oWxky7.png) Blender has stopped working Windows can check online for a solution to the problem. - Check online for a solution and close the program. (Didn't work) - Close the program Additional Information: > Problem signature: ``` Problem Event Name: APPCRASH Application Name: blender-app.exe Application Version: 2.7.2.0 Application Timestamp: 5446569e Fault Module Name: MSVCR120.dll Fault Module Version: 12.0.21005.1 Fault Module Timestamp: 524f83ff Exception Code: c000001d Exception Offset: 0000000000092bc3 OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1030 Additional Information 1: 9c5b Additional Information 2: 9c5b99d1538af1465d6588ee6e30c6d2 Additional Information 3: ffa6 Additional Information 4: ffa6c829f7fac5222bb75dc93477b4fc ** ``` **Exact steps for others to reproduce the error** I don't know what causes the error, all i know s what the application tells me, as listed above.
Author
Author
Added subscriber: @Shazarakk
Member
Added subscriber: @Blendify
Member
Do you have c++ redistributable 2013
Do you have the newist graphics cards?
Do you have c++ redistributable 2013 Do you have the newist graphics cards?
Member
Sorry drivers
Sorry drivers
Member
Try using the newest version of Blender from https://builder.blender.org/download/
Try installing the latest drivers manly for your GPU
If you just installed windows 7 make sure you have Visual C++ Redistributable Packages for Visual Studio 2013 link :http://www.microsoft.com/en-us/download/details.aspx?id=40784
look for this file on your computer and upload it to this thread C:\Users\USERNAME\AppData\Local\Temp\blender.crash.txt
use the corresponding file and place it next to blender.exe
Windows 32-bit
http://download.blender.org/ftp/sergey/softwaregl/win32/opengl32.dll
Windows 64-bit
http://download.blender.org/ftp/sergey/softwaregl/win64/opengl32.dll
Try using the newest version of Blender from https://builder.blender.org/download/ Try installing the latest drivers manly for your GPU If you just installed windows 7 make sure you have Visual C++ Redistributable Packages for Visual Studio 2013 link :http://www.microsoft.com/en-us/download/details.aspx?id=40784 look for this file on your computer and upload it to this thread C:\Users\USERNAME\AppData\Local\Temp\blender.crash.txt use the corresponding file and place it next to blender.exe Windows 32-bit http://download.blender.org/ftp/sergey/softwaregl/win32/opengl32.dll Windows 64-bit http://download.blender.org/ftp/sergey/softwaregl/win64/opengl32.dll
Author
i have all the latest drivers ad all prerequisites, including C++
i have also downloaded and tried both opengl32.dll files
it still crashes.
i have all the latest drivers ad all prerequisites, including C++ i have also downloaded and tried both opengl32.dll files it still crashes.
Member
Don't use both the open gl files only th 64 bit one
Member
Please use the test builds
Author
i tried both just in case
and the test builds don't work
i tried both just in case and the test builds don't work
Member
Member
@Shazarakk, I'd recommend testing with the ".zip"s rather than the installers. Could you also test if it works if you launch it from the folder instead from the desktop link?
Member
@JulianEisel you know what we need... A blender crash project.
Member
@Shazarakk please try and launch blender using the command line... Command prompt
Author
I have tried both the zip's and the command line, none of them work, (the command line simply says it can't find the specified file
Member
@JulianEisel can you help him
Member
It looks like you don't have Service Pack 1 installed. It is really important to keep OS + graphics drivers + Blender up-to-date, otherwise issues like this may appear.
Author
@JulianEisel i do have SP 1
Member
@Shazarakk what steps did you take in using the command prompt... did you navigate to the folder with blender.exe
Author
i tries using the direct exicute, when that didn't work i searched furiously for the navigate code, but i couldn't find ti, so i haven't tried that yet no.
Member
Could you just give us the path to the blender.exe? I'll tell you how to do it then
Author
C:\Users\shazarakk\Desktop\blender-2.73-8a28895-win64
Member
Okay, so just enter the following commands:
  • cd /D c:\
  • cd Users\shazarakk\Desktop\blender-2.73-8a28895-win64
  • blender.exe
(Wrote this out of my head so no guarantee it works, but it should)
Okay, so just enter the following commands: * cd /D c:\ * cd Users\shazarakk\Desktop\blender-2.73-8a28895-win64 * blender.exe (Wrote this out of my head so no guarantee it works, but it should)
Author
Thank you for the code, but it still crashes
Member
In your description are you saying that your CPU is running at 100% at start up
Member
@Shazarakk, yes, but the console should now show proper information that could help us. So could you paste that in here?
Author
i never said such a thing, it is averaging out at 6-7% ATM, ( i have about 30 tabs open, two of them being youtube, currently streaming).
I don't know what it is on start up, since my monitoring programs don't boot before the load is released
i never said such a thing, it is averaging out at 6-7% ATM, ( i have about 30 tabs open, two of them being youtube, currently streaming). I don't know what it is on start up, since my monitoring programs don't boot before the load is released
Member
GPU 2 70C 100% load
" Processor does not exceed 54C at 100% load 99% cache usage. GPU 1 80C 100% load. GPU 2 70C 100% load "
Author
i have a custom loop, unfortunately the gpu waterblocks had a manufacturing issue in them, or took damage later on, so right now they are running on air, while my CPU is running on the equivalent to 8 120mm rads (360mm dual thickness, and 120mm dual thickness, both push/pull) i will get the GPU blocks installed when i clean and refill my loop
Member
So, this really looks like a duplicate of #42308. The comments in there describe a way that should most likely solve this.
Member
Closed as duplicate of #42308
Reference: blender/blender#43115
