Revert file in session
Allow a "bam revert" command, which removes a file within a session and checks it out from the server again.
For a start, it would simply to a new bam checkout and then copy over only that file (so we keep the mapping - in a similar way to bam update). One important aspect tough is checking out the exact same revision of the session (which we do not keep track of currently).
Francesco Siddi (fsiddi) set Type to Design.
Francesco Siddi (fsiddi) created this task.
Francesco Siddi (fsiddi) raised the priority of this task from to Normal.
Probably its better/easier - if we just impliment local caching, since we need this anyway.
Then we can very quickly get the original file from cache. (and re-run the remapping operation).
We could also (very short term). do a checkout and just *hope* that the file reverted wasn't updated by anyone else - in practice its probably OK mostly, but its very much a temporary solution.
Have local caching working and bam revert uses the original files and replays edits on them to revert.
Committed rBAM535886c9155e64ed81a2b34c7104d08f36b267ac
