Correct aspect does not work after UV unwrap.
Closed, InvalidPublic
Win 7 64, GTX 560
Broken: 2.73
Map size is 2048*1024.
Unwrap almost does not change after unchecking "Correct aspect" in the unwrapping options.
Open attached file, unwrap mesh, press F6 above 3d window, uncheck "Correct aspect".
Maxim Tkachenko (maleficmax) raised the priority of this task from to Needs Triage by Developer.
Maxim Tkachenko (maleficmax) updated the task description. (Show Details)
I forgot to say, that after appending object into the new file, problem dasappears.
Sergey Sharybin (sergey) lowered the priority of this task from Needs Triage by Developer to Normal.Jan 20 2015, 10:55 AM
Stuff things to work here, but i'm not totally expert of aspect correction for UVs.
@Campbell Barton (campbellbarton), mind having a glance?
Whats happening here is the image isn't connected to the mesh (as far as Blender is concerned)
The image happens to be showing, but you dont have any cycles image textures selected.
You need to add a material and make that material use the image.
... or switch to "Blender Internal" renderer.
closing.
