Export and Import Keyconfig causes full screen
Closed, InvalidPublic
Windows 7 pro Nvidia GTS 450
Broken: 2.73.a bbf09d9,
**Export and Import Keyconfig*
  1. Go to User Preferences > Input. Add a keyconfig preset.(+) Name it.
  2. Go to Window. Replace search menu with "shift spacebar"
  3. Go to Screen - Screen Global replace toggle quad view with "spacebar"
  4. Export keyconfig and name it.
  5. Exit and open blender. Go to User Prefrences > Input
  6. Import previously exported keyconfig.
  7. Scroll down to see all the objects. (camera, cube, lights etc.)
  8. Select camera.
  9. Boooom. Full screen. You have to exit blender :(
Murat Egretli (murattige) raised the priority of this task from to Needs Triage by Developer.
Murat Egretli (murattige) updated the task description. (Show Details)
Murat Egretli (murattige) set Type to Bug.
Julian Eisel (Severin) claimed this task.EditedJan 28 2015, 12:42 AM
Can reproduce here. The good news: You don't have to restart Blender, you can just use Ctrl+Rightarrow/Leftarrow to change the screen. It happens because of this stupid automatically created shortcut:
This shortcut executes the toggle fullscreen operator each time an action is done (also if you mouse hover buttons for example).
Will have a look the next week.
Julian Eisel (Severin) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.Jan 28 2015, 12:43 AM
This isnt a big, shift-spacebar is already a key shortcut for toggling maximized area.
this has to be removed in your key configuration.
@Campbell Barton (campbellbarton), not sure... think you're understanding the issue a bit wrong (trying the exact same steps as mentioned above results in serious glitches which I don't think are because of conflicting shortcuts or so). The fullscreen op from my screenshot is intended to be handled on EVT_ACTIONZONE_FULLSCREEN, but for some reason gets handled on mouse events. Wanted to investigate further but didn't find the time yet.
