Cycles dupli object baking issues #43553
Open
opened 2015-02-03 21:25:48 +01:00 by Vilem Duha · 23 comments
Member
nvidia g880m
Broken: blender-2.73-d56c9fb-win64
Worked: (optional) probably never
when assigning object as duplis to some mesh, and then trying to bake these duplis to another mesh, duplis appear black. But in normals mode, it works, so they are there, just without material or something.
Also, you can see that the duplis are there actually twice, one offset quite strongly. In some other file, I got them also four times...
bakebug.blend
open the file, hit bake.
the group of objects in the ceter bakes to the cube.
also, you can see another group of objects, where duplis have been made "real" and it works well, it's group of objects called "fine", baking to the cube works well with seemingly same meshes.
**System Information** nvidia g880m **Blender Version** Broken: blender-2.73-d56c9fb-win64 Worked: (optional) probably never **Short description of error** when assigning object as duplis to some mesh, and then trying to bake these duplis to another mesh, duplis appear black. But in normals mode, it works, so they are there, just without material or something. Also, you can see that the duplis are there actually twice, one offset quite strongly. In some other file, I got them also four times... **Exact steps for others to reproduce the error** [bakebug.blend](https://archive.blender.org/developer/F140745/bakebug.blend) open the file, hit bake. the group of objects in the ceter bakes to the cube. also, you can see another group of objects, where duplis have been made "real" and it works well, it's group of objects called "fine", baking to the cube works well with seemingly same meshes.
Author
Member
Dalai Felinto was assigned by Vilem Duha 2015-02-03 21:25:48 +01:00
Author
Member
Added subscriber: @VilemDuha
#83527 was marked as duplicate of this issue
#76864 was marked as duplicate of this issue
#54133 was marked as duplicate of this issue
#46224 was marked as duplicate of this issue
Author
Member
just foud the reason for the fact that there are actually more duplis:
when you hit bake, you can even see in the viewport for a second, that the code triangulates the faces of the dupli parent - this causes double count of the duplis ;)
just foud the reason for the fact that there are actually more duplis: when you hit bake, you can even see in the viewport for a second, that the code triangulates the faces of the dupli parent - this causes double count of the duplis ;)
Author
Member
Also,
forgot to mention - the actual dupli parent renders too, while it shouldn't render at all.
It also renders totally black. You can see it if you make the duplicated object smaller, there are more artifacts coming not from the spheres, but also from the parent object.
Also, forgot to mention - the actual dupli parent renders too, while it shouldn't render at all. It also renders totally black. You can see it if you make the duplicated object smaller, there are more artifacts coming not from the spheres, but also from the parent object.
Added subscribers: @Sergey, @brecht
The issue is that BKE_mesh_new_from_object() (or the python functions that use it: object_to_mesh(), new_from_object()) don't return the dupli groups converted to the final mesh.
What Blender does (in Cycles and in exporters) is to use object.dupli_list_create() and grab the objects and their matrices from it.
The options I thought of:
  1. To handle all of this in object_bake_api.c.
In order to do that I would replace all the BKE_mesh_new_from_object() calls by a new function that would get all the meshes of all the dupli objects, and join them as the final mesh to return. I have an idea of how to do this (but for the 'join'), but the biggest issue is that we need to guarantee that the mesh is "joined" just as it would in Cycles. In order to keep the primitive_id consistent.
  1. To handle this by changing the api to pass the object id and the object matrix.
This way we can pass each of the individual duplicated objects as an individual High Poly object to bake from.
@brecht , @Sergey, any thoughts? I would like to have an agreed design before I head to the implementation.
The issue is that `BKE_mesh_new_from_object()` (or the python functions that use it: `object_to_mesh()`, `new_from_object()`) don't return the dupli groups converted to the final mesh. What Blender does (in Cycles and in exporters) is to use `object.dupli_list_create()` and grab the objects and their matrices from it. The options I thought of: 1. To handle all of this in `object_bake_api.c`. In order to do that I would replace all the `BKE_mesh_new_from_object()` calls by a new function that would get all the meshes of all the dupli objects, and join them as the final mesh to return. I have an idea of how to do this (but for the 'join'), but the biggest issue is that we need to guarantee that the mesh is "joined" just as it would in Cycles. In order to keep the primitive_id consistent. 2. To handle this by changing the api to pass the `object id` and the `object matrix`. This way we can pass each of the individual duplicated objects as an individual High Poly object to bake from. @brecht , @Sergey, any thoughts? I would like to have an agreed design before I head to the implementation.
Added subscriber: @dfelinto
@dfelinto, passing object matrix seems cleaner solution for me and easier to implement. And would work faster than joining meshes i think.
At least i'd try matrix approach and see if all the corner cases are solved with this.
@dfelinto, passing object matrix seems cleaner solution for me and easier to implement. And would work faster than joining meshes i think. At least i'd try matrix approach and see if all the corner cases are solved with this.
Added subscriber: @mont29
And would work faster than joining meshes I think.
It would be faster, but the memory footprint will go through the roofs.
I think we should first prioritize #41092 (or rather D772) before this one then.
> And would work faster than joining meshes I think. It would be faster, but the memory footprint will go through the roofs. I think we should first prioritize #41092 (or rather [D772](https://archive.blender.org/developer/D772)) before this one then.
This issue was referenced by 1eb561bfc1e357ab50c90f18632c485d657c8007
Changed status from 'Resolved' to: 'Open'
:/ I pushed it to the wrong repository, it was never intended to go to blender.org
For the records, those are the test files I'm using lately. They both fail to bake properly at the moment.
dupligroup_colored.blend
dupligroup_textured.blend
For the records, those are the test files I'm using lately. They both fail to bake properly at the moment. [dupligroup_colored.blend](https://archive.blender.org/developer/F197156/dupligroup_colored.blend) [dupligroup_textured.blend](https://archive.blender.org/developer/F197157/dupligroup_textured.blend)
Added subscriber: @AidyBurrows-1
Brecht Van Lommel changed title from baking duplicate objects renders them black in Cycles, and also multiple times... to Cycles dupli object baking issues 2016-02-21 15:13:36 +01:00
Dalai Felinto removed their assignment 2019-12-23 16:37:50 +01:00
Member
Added subscribers: @sanne, @lichtwerk, @LazyDodo
Member
Added subscribers: @SteffenD, @mano-wii, @iss
Member
Added subscriber: @Lluc3D
Philipp Oeser removed the
label 2023-02-09 13:56:49 +01:00
6 Participants
Reference: blender/blender#43553
