Blender Does Not Account for Suspend #43597
Reference: blender/blender#43597
64bit Manjaro Linux, kernel 3.14.29
CPU: AMD Phenom II 970 Deneb quad-core
GPU: nVidia GTX 650 Ti, driver 343.36
Broken: Buildbot Build 2.73
4cbf2ebd
Worked: Not sure this ever worked
Each night when I go to bed, I put my computer into suspend mode, rather than just leaving it on or shutting down. Most applications I leave running during the night don't have any problems. Blender, however, does. Two main problems I have observed:
Fixing the issue should be simple (in theory). It could be done by detecting when the computer suspends or hibernates (most OS's should provide an interface to detect this, but I could be wrong) and then clear/reload the data stored on the GPU.
Error output I got: CUDA_Errors.txt
Added subscriber: @ZauberParacelsus
Added subscribers: @Sergey, @Psy-Fi, @mont29
Not quite sure we can do anything here… Afaik, suspending an OpenGL (or DirectX, for what matters) application is always problematic, it uses specific low-level access to the GPU driver, unlike regular applications which only use OS APIs. Antony or Sergey should know better here, though.
@mont29 - Yeah, that's why I said it would be simple "in theory". And because I know that nothing is truly simple with programming, lol.
You can think of hibernation as something totally transparent for application -- it just should not notice anything happened. You can't fix it from userspace (aka blender in this case). Some workarounds are probably possible, but it'll be really nasty code which would still fail in loads of cases (for example on my laptop probability of ogl stuck at 100% CPU usage after hibernation is quite high, this you can't fix from blender without restarting it).
So thanks for the report, but we can't really do much about this. Ideally nvidia should look into their driver, but from quick google seems they're not really interested in solving this =/
There is such a thing as a robust context in newer OpenGL, check https://www.opengl.org/registry/specs/ARB/robustness.txt. We could try using it but I'm not certain it will fix resets in CUDA contexts...Any CUDA guru here who might know? I'd suggest to use command-line only rendering for such tasks for now.
@Psy-Fi, i'm not sure why exactly the robust contexts will help? From the problem description it just seems driver is flacky enough to not ensure row refresh signals are keeping to happen on video card's SDRAM, which eventually leads to textures corruption. At least that's what likely happening based on the timing and symptoms. Not totally clear why other contents of VRAM are fine tho.
In any case, opengl+hibernation issue is not something blender-specific, it's kernel+driver specific. My main desktop seems to survive it all just fine i.e.
CUDA+hibernation is major problems, being discussed in loads of places. Driver is just to be fixed..
