UV wrong unwrap after changing object origin #43627
6 Participants
Reference: blender/blender#43627
Windowns 8.1 - nVidia GTX 660
Broken: 2.73a
Changing object origin result incorrect UV unwrap.
wrong_uv.blend
Also, when UV unwrap, changing island margin values result different shapes in in UV islands, not scaled, distorted on x or y.
Added subscriber: @Dorothy
forgot to add one step, after changing dimensions, I've apply rotation and scale.
full steps again here (sorry i did not find a way to modify original post):
Added subscriber: @NikoLeopold
i guess you used Smart UV Project?
by 'incorrect' you mean different from the last projection?
obviously Smart UV Project is not able to ensure the exact same UV map layout for every configuration of the object. i am not sure if that is considered a bug though.
about the distortion with increased island margin: it seems its just enforcing the island margin, without trying to presevere a perfect orthogonal projection, since thats not being done for every face anyway when the angle angle limit is at a reasonable size. i think it is trying to optimize the use of the uv map space? im really not sure, but im not sure if thats considered a bug either.
anyway, someone more experienced in this module will have to tell.
Added subscribers: @mont29, @JulianEisel
@mont29 what would you say here? Is this expected?
yes, I am talkin about Smart UV Project.
And this is a bug, a perfect square should not produce a rectangle UV.
That depends on the method you use. Every method uses a different algorithm using different conditions, parameters, ... So not every method brings the same result!
With all respect, please ask someone who work on UV unwrap about this bug report, I am sure this is a major bug, if you put test checkers on wrong uv you get distorted texture, incorrect mapping.
Added subscriber: @GregZaal
Added subscriber: @ideasman42
Looking into this, I can't redo the problem with the change in origin giving the incorrect UV layout.
Can you show an image of whats considered correct & incorrect?
A week without reply. Due to the policy of the tracker archiving the report for until requested information is provided.
