CyclesBaking: baking problem
linux 64
blender 2.73
In cycles i can bake only one hipoly model to lowpoly. But in Internal baking it works ok.
Here is my tests:
Here is the file to test:
https://dl.dropboxusercontent.com/u/26887202/blender/test_bake_lowpoly.blend
  • Open the file
  • Press "Bake" in Cycles or in Internal.
Related Objects
paul geraskin (mifth) updated the task description. (Show Details)
paul geraskin (mifth) raised the priority of this task from to Needs Triage.
paul geraskin (mifth) set Type to Bug.
@Dalai Felinto (dfelinto) said that this is a bug. And he asked me to create this report.
@Andy Davies (metalliandy) could you possibly do your testing routine here to help led me the way? I confirmed the bug but I'm yet to pinpoint what may be causing it.
(maybe it's the fact that the high poly objects are not in the same place as the low poly? If I'm not mistake we currently take the world coordinate not the local for the calculations)
Ok I found the issue. This is that reproduced in an actual simple/small file
Easy workaround: unlink the normal map from your low poly material.
Actual issue: the error of circular dependency is preventing all but the first object from being baked. We should either prevent all of them, or to allow all of them (and just throw the error as we are doing). I'll check what Blender Internal bake does.
Julian Eisel (Severin) triaged this task as Confirmed priority.Feb 11 2015, 2:15 PM
Julian Eisel (Severin) added a project: Cycles.
You're welcome, thanks for the report. By the way, if you can take a look at the file I uploaded it could help you for future reports (as in, how simple can/should a report be). I understand that sometimes there is no time to produce those, but it definitively help the developer. cheers
ok. i'll take into account. :)
This comment was removed by paul geraskin (mifth).
