FreeStyle SVG Exporter: "fill contours" fails when using multiple render layers #43635
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#43635
Win7 x64
2.73, b4d8fb5
When using multiple render layers and activating "fill contours", the the filling will not work properly.
Attached is a simple .blend{F142551}file, and two .svgs 0001.svg, 0002.svg, showing the result. I also attach a screenshot to immediately visualize the problem: the bar is on render layer 2 and should be solid all the way through.
Added subscriber: @noone
Added subscriber: @flokkievids
Thanks for the problem report. Will look into it.
Added subscriber: @kjym3
Thanks for this bug report, It highlights some serious issues with the ordering of the generated SVG.
You can find an updated version of the exporter here (paste it over the existing one; its location can be found under user preferences > addons > freestyle svg exporter > file). I hope this fixes the problem.
@kjym3
Most of this problem is caused by mistakes on my side. I fixed the hierarchy, so that the ordering is correct. Another problem was that two renderlayers can have two different line sets with the same name, which confuses the exporter. I've fixed this by prepending the name of the render layer: this should make all names unique.
This issue was referenced by
36d55fccfc
Closed by commit
36d55fccfc
