Export texture coordinates are wrong after move them in UV Editor #43637
Reference: blender/blender#43637
Create a simple cube with texture. 2x2x8
Adjust UI coordinates to have correct ratio. Had move move them around.
Export to collada and the UV coordinates in export are incorrect in the dae file.
See the following:
blender file:beam2.blend
collada export file:beam2.dae
Added subscriber: @ShawnFisk
Added subscriber: @Blendify
Added subscribers: @GaiaClary, @JulianEisel
@GaiaClary, is this a known issue/limitation or a real bug?
Yes, this is a bug. How do I know? I know how bug was created because I had the same issue in my first implementation but test cases failed. Since I could not wait for you to fix. I started a project to read the blender file directly. This is what I found out:
Read Vertex:(generic code) (If figure you do not want to see real implementation).
load mVerts from MVert data section
load mPolys from MPloy data section
load mLoops from MLoop data section
// generate vertex sets for each face.
int faceIdx = 0;
for(MPoly ploy : mPolys) {
You are doing the following for generation texture mapping coordinates (which seems logical but is wrong).
load mLoopUVs from MLoopUV data section
// Wrongly generate texture UV coordinates for each face, exactly what the python code is doing.
int faceIdx = 0;
This is what is should be in my opinion:
// Correctly generate texture UV coordinates for each face, the fix
the MLoopUVs is the UVs for each face, my example a box with each face having two triangles. 6 vertices per side there are 6 sides therefore 36 UV coordinates. The MLoopUV data sections is setup based on the MLoop (start, total), therefore my algorithm reads it correctly. Needless so say, I wrote lots of tooling to figure out the blender format when it comes to UV coordindates.
I hope this help to track down and fix the issue.
I tested this and i could not find an issue with the UV coordinates. The exporter creates the UV vertices as expected. Here is the part of the code that does it:
The exported dae file contains:
3 UV coordinates per triangle
12 triangles in cube
36 UV coordinates in total
Please can you explain in which way the UV coordinates are wrong for you? Maybe i misunderstand the issue completely.
As a sidenote: Seam information is get lost during export. But as far as i could see this is because collada does not support seam information (please correct me if i am wrong).
No answer for more than a week -> closed! Sorry, but we have to be very strict in order to keep our bug tracker organized. We can consider reopening after we've got the requested information.
