Hair Clumps Point to Scene Center When Density is Texture-Controlled
64bit Manjaro Linux, kernel 3.14.32
CPU: AMD Phenom II 970 Deneb quad-core
GPU: nVidia GTX 650 Ti, driver 343.36
Broken: 2.73 dev (hash 2e9105cc )
When a hair system's density is controlled by a texture, any clumped hair will be stretched out and point towards the center of the scene. If clump is at 0.5 for example, it'll stretch half the way, and if clump is at 1.0 it'll stretch all the way.
This .blend file reproduces the issue:
A snapshot of the bug, in case it does not repro on other system's for some reason:
Julian Eisel (Severin) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.Feb 16 2015, 10:18 PM
Confirmable, also using 2.73.
And of course the next one that needs @Lukas Toenne (lukastoenne)'s attention :P Lukas, is this intended/expected?
I can confirm this bug as well for a project I'm working on. Oh man I hope this one can be fixed soon! :)
@Lukas Toenne (lukastoenne), In case you didn't see it, @Krzysztof Rećko (chrisr) made a patch for it waiting for your review. Are you available to check it soon?
I'm not sure the patch helped. As of RC3 the issue is still present.
@Chad Gleason (fahr), the patch was only submitted, not committed, so it's not in master yet.
Now it is in master ;P
I just loaded a hair scene of mine using 2.74 offical release and this bug is back!! Did the patch get removed from master? Is there a build where I can get it back? I'm desperate at this point. I'm on a deadline and this was fixed a few weeks ago. :P
@Chad Gleason (fahr), the patch wasn't included in official 2.74 release (committed only 6 days before release...), but it is in the newest build from buildbot (https://builder.blender.org/download/) and everything should work fine there :)
Ok, got it! Thanks!
Just a note to say that this bug is still there in the version 2.78a. It acts a little differently throught. Sometime, I have the hair particle stretched like before,but, sometime, I just get a furball in the center of my scene... Is there a correctife I could find somewhere?
