FBX 7.4 Binary Exporter replaces all meshes with the same name when working with linked libraries. #43707
Closed
opened 2015-02-17 11:10:46 +01:00 by Bart Heijltjes · 9 comments
Windows 8.1
Broken: 2.73 hash b4d8fb5
When using the FBX 7.4 Binary exporter on a file with linked libraries, all meshes that share a name are replaced with the mesh from the last linked file.
  1. Create Alice.blend with a cube object called Alice in it. Keep the standard mesh name 'Cube'.
  2. Create Bob.blend with a sphere object called Bob in it. Change the mesh name from 'Sphere' to 'Cube'. Add Bob to a group called 'Bob'.
  3. In Alice.blend, 'Add Linked' (Ctrl+Alt+O), browse to the group Bob in Bob.blend and add it to the scene.
  4. You should now have a cube Alice and a sphere Bob in your scene.
  5. Export using the FBX 7.4 Binary exporter to AliceAndBob.fbx
  6. Open AliceAndBob.fbx in your favourite model viewer. You should see two spheres, rather than a cube and a sphere.
  7. (optional) Create Carol.blend with a cone shape and follow the previous steps. AliceAndBobAndCarol.fbx should end up all cones.
aliceandbobandcarol.fbx
alice.blend
bob.blend
carol.blend
**System Information** Windows 8.1 **Blender Version** Broken: 2.73 hash b4d8fb5 When using the FBX 7.4 Binary exporter on a file with linked libraries, all meshes that share a name are replaced with the mesh from the last linked file. **Exact steps for others to reproduce the error** Based on a (as simple as possible) attached .blend file with minimum amount of steps 1. Create Alice.blend with a cube object called Alice in it. Keep the standard mesh name 'Cube'. 2. Create Bob.blend with a sphere object called Bob in it. Change the mesh name from 'Sphere' to 'Cube'. Add Bob to a group called 'Bob'. 3. In Alice.blend, 'Add Linked' (Ctrl+Alt+O), browse to the group Bob in Bob.blend and add it to the scene. 4. You should now have a cube Alice and a sphere Bob in your scene. 5. Export using the FBX 7.4 Binary exporter to AliceAndBob.fbx 6. Open AliceAndBob.fbx in your favourite model viewer. You should see two spheres, rather than a cube and a sphere. 7. (optional) Create Carol.blend with a cone shape and follow the previous steps. AliceAndBobAndCarol.fbx should end up all cones. [aliceandbobandcarol.fbx](https://archive.blender.org/developer/F144176/aliceandbobandcarol.fbx) [alice.blend](https://archive.blender.org/developer/F144177/alice.blend) [bob.blend](https://archive.blender.org/developer/F144178/bob.blend) [carol.blend](https://archive.blender.org/developer/F144179/carol.blend)
Author
Author
Added subscriber: @WispBart
Added subscriber: @Sergey
Added subscriber: @mont29
@mont29, any ideas here?
Bastien Montagne self-assigned this 2015-02-17 13:54:53 +01:00
Meh, yes, quite simple actually, exporter is not aware at all of libraries namespace stuff… will fix asap.
This issue was referenced by 17a28df49c
This issue was referenced by 17a28df49c35da5670c2964f29f0768d650a1d0a
Closed by commit 17a28df49c.
Reference: blender/blender-addons#43707
