Videotexture does not use sky color for off-screen rendering #43822
Reference: blender/blender#43822
Tested on OS X 10.9 as well as Windows 7
Broken: 2.73 Current Master
Worked: Never?
The videotexture render-to-texture function defaults to (0,0,1) for the sky color, regardless of what it is set in the world settings. It should use the World Sky color.
See sample file attached. vidTextureBug.blend
Added subscriber: @MikePan
Ah sorry, meant to put this under 'Game Engine', but somehow missed it.
Added subscriber: @hg1
Actually that is no bug. This is more a wanted feature.
You can set the background color with Python (mirror.source.background = [64, 50, 37, 255])
To calcualte the same color, switch the colorwheel to Hex and 40 32 25 and calculate to decimal values.
I see. Although I would expect the default behaviour to take the color from the sky. Python can used to override when needed. The current behaviour seems unintuitive.
Added subscriber: @JorgeBernalMartinez
The patch seems easy (#43822.patch) but it has another issue related:
As we use getBackColorRed/Green/Blue as we use getAmbientColorRed/Green/Blue, we always get the ambient color. HG1, is this issue fixed with yours differential patches ( I refer to D148 an on)?
I suggest to add this feature after my mist patches are in the trunk (after Blender 2.74 release), because one of my patches D158 will remove the getBackColorRed() methods.
After the mist patches we can add a getBackColo() which returns m_backgroundcolor and initialize the background color for the video texture module.
Ok.
Analysing the code I saw that if we force the mirror background color to the world background color we could have issues when the mirror is located into a structure (i.e. a room) as we will apply an outside color to one object that is inside of a structure which can't see or receive colors from outside.
Then, I propose you the following solution:
is it a valid/acceptable proposal?
Mike, is it ok for you the solution?
I appreciate the work you've put into this.
But I am afraid I don't understand the issue you described. If the mirror is in an enclosed room, wouldn't it render and reflect the room instead of the sky color? While it's relatively trivial to setup a script to use the world color, wouldn't a sensible default be the skycolor in the first place? The Api can be used to override the color if desired.
This issue was referenced by
dc95ca92ca
Closed by commit
dc95ca92ca
