OBJ importer problem #43863
Closed
opened 2015-03-02 15:23:50 +01:00 by Everton Schneider · 10 comments
Ubuntu 14.10 - GeForce GT 740/PCIe/SSE2
Broken: 2.73 Hash: d2b6c6f
Apparently the ngons option in import settings are missing, but could be something bigger behind... I don't know.
A simple OBJ file is imported well but a more complex obj file can't be imported.
This is the terminal output:
importing obj '/home/ever/Desktop/Pascoa_HAVAN/Originais/Prensa_008.obj'
parsing obj file...
14.5748 sec
loading materials and images...
0.0002 sec
building geometry...
verts:706606 faces:1057588 materials: 24 smoothgroups:0 ...
File "/home/ever/blender-build/install/linux/2.73/scripts/addons/io_scene_obj/__init__.py", line 144, in execute
  return import_obj.load(self, context, **keywords)
File "/home/ever/blender-build/install/linux/2.73/scripts/addons/io_scene_obj/import_obj.py", line 1098, in load
  dataname,
File "/home/ever/blender-build/install/linux/2.73/scripts/addons/io_scene_obj/import_obj.py", line 611, in create_mesh
  blen_uvs.data[lidx].uv = verts_tex[face_uvidx]
ValueError: bpy_struct: item.attr = val: sequences of dimension 0 should contain 2 items, not 3
**System Information** Ubuntu 14.10 - GeForce GT 740/PCIe/SSE2 **Blender Version** Broken: 2.73 Hash: d2b6c6f **Short description of error** Apparently the ngons option in import settings are missing, but could be something bigger behind... I don't know. A simple OBJ file is imported well but a more complex obj file can't be imported. This is the terminal output: importing obj '/home/ever/Desktop/Pascoa_HAVAN/Originais/Prensa_008.obj' parsing obj file... 14.5748 sec loading materials and images... 0.0002 sec building geometry... verts:706606 faces:1057588 materials: 24 smoothgroups:0 ... Traceback (most recent call last): ``` File "/home/ever/blender-build/install/linux/2.73/scripts/addons/io_scene_obj/__init__.py", line 144, in execute return import_obj.load(self, context, **keywords) File "/home/ever/blender-build/install/linux/2.73/scripts/addons/io_scene_obj/import_obj.py", line 1098, in load dataname, File "/home/ever/blender-build/install/linux/2.73/scripts/addons/io_scene_obj/import_obj.py", line 611, in create_mesh blen_uvs.data[lidx].uv = verts_tex[face_uvidx] ``` ValueError: bpy_struct: item.attr = val: sequences of dimension 0 should contain 2 items, not 3 location: <unknown location>:-1 location: <unknown location>:-1
Added subscriber: @EvertonSchneider
Member
Added subscriber: @MartijnBerger
Member
We will need that OBJ file or one that triggers the same condition.
Ok, Here is the file that I'm working with.
https://www.dropbox.com/s/f49451n1dkerjpa/Prensa_008.zip?dl=0
Ok, Here is the file that I'm working with. https://www.dropbox.com/s/f49451n1dkerjpa/Prensa_008.zip?dl=0
Bastien Montagne self-assigned this 2015-03-02 19:28:24 +01:00
Wow, that is a huge scene !
Issue confirmed, fix incoming (and it imports in 20 seconds here, who said our importer was slow? :P ).
Wow, that is a huge scene ! Issue confirmed, fix incoming (and it imports in 20 seconds here, who said our importer was slow? :P ).
This issue was referenced by 514c08f839
This issue was referenced by 514c08f839d57c73a0f616198a8ea8327b143e09
Closed by commit 514c08f839.
Wow!
How fast! Thank you, team!
Wow! How fast! Thank you, team!
Reference: blender/blender-addons#43863
