Grease Pencil: No easy way to exit from continuous draw mode when using tablet with no keyboard #43867
5 Participants
Reference: blender/blender#43867
Surface Pro 3
i7
6 GB RAM
Windows 8.1
Broken: 2.73a
Worked: No sure if it ever would have worked.
Once you enable continuous draw mode and start drawing the only way to exit (that I know of) is to hit the escape key. However, if you are using a tablet with no keyboard (i.e. using a touch pen) then you are stuck and the only way to exit the drawing is to call up the "soft keyboard"
Open Blender with default cube using a tablet
Enable grease pencil in properties ("N") panel
Select Grease pencil tab
Check continuous drawing option
Click draw.
Now you are stuck... with no quick way out.
Added subscriber: @AndrewButtery
No easy way to exit from continuous draw mode when using tablet with no keyboardto Grease Pencil: No easy way to exit from continuous draw mode when using tablet with no keyboardAdded subscriber: @Sergey
Joshua, mind having a look? Thanks! :)
Added subscriber: @ideasman42
We could make it so RMB exits - as with other tools.
The only problem with using RMB here is that RMB-drag currently/now activates the eraser instead.
There are several things I'm considering doing here... actually, on second though, they're not really mutually exclusive, so I might just do all of them ;)
Ok, changed this to a design task, to get some feedback from the UI team on this.
Regarding the implementation of click-outside-area to exit:
From my investigations, it seems that my original idea of just checking whether the CTX_wm_area(C) == area when starting operator/first stroke doesn't actually work, since the current area doesn't actually change when a modal operator has control. (IIRC, this wasn't always the case for the Grease Pencil operator - see line 1800 in gpencil_paint.c for a check that used to do something, and now doesn't run). Instead, in the current implementation, it would be necessary to instead check if the mouse is outside the bounds for the area/region in question to do this.
While the area/locking behaviour for modal operators does make sense in some situations, it also has some problems too
Discussing these issues with Campbell a bit in IRC, an interesting point came up that perhaps ALL modal operators should be made to stop working once you click outside the area where you invoked the tool in the first place. (Note: we're referring to Areas here and now Regions). That discussion should perhaps be separate from this one here, but I thought it would be useful to bring this option up here now, since it would be a nice solution to the original problem here (and with other uses for things like the knife tool, etc.)
On a side note, D1187 is a patch which would enable again the ability to tag specific operators as not being locked to the initial region/area combination. (I'm just noting this here more for my own reference, since I thought I'd seen this committed already when it hadn't.)
This issue was referenced by
be0dcd4e34
Closed by commit
be0dcd4e34
