Freestyle traces objects that are invisible to camera
Closed, InvalidPublic
Ubuntu 14.10 64-bit
Broken: 2.73a bbf09d9
Freestyle traces objects that have Camera Ray visibility disabled. Example:
The object is a plane that has camera ray visibility turned off.
Enable Freestyle, and turn off 'Camera' under the objects ray visibility tab. Render.
Computer Guy (Terrance8d) set Type to Bug.
Computer Guy (Terrance8d) created this task.
Computer Guy (Terrance8d) raised the priority of this task from to Needs Triage by Developer.
Julian Eisel (Severin) closed this task as Invalid.Mar 12 2015, 9:24 PM
Julian Eisel (Severin) claimed this task.
Freestyle is like an own render engine that renders after the base render is done. It uses it's own settings and therefore isn't affected by the settings of the base render engine (in this case Cycles). Not sure if this would be good to have but even if so, we'd consider this as a todo, not as a bug.
If you want to completely hide the object for rendering, you can deselect the render-visibility option from the Outliner.
Anyway, thanks for the report @Computer Guy (Terrance8d), but everything works as expected here :)
