Setting filepath of an image reloads it, which breaks all kind of generated content (including baking). #43985
Reference: blender/blender#43985
Broken: (example: 2.69.7
4b206af
, see splash screen)Worked: (optional): not sure if ever.
I tried to make some advanced baking script.
I hit this error, where setting the file path AFTER baking erases the image pixels to black. interesting is, that when I set the filepath before, it works.
open file, run first script on upper left - that simply bakes into the image.
run the second script, which tries to set name and save. see the blackness!
bakebug.blend
Added subscriber: @VilemDuha
Added subscribers: @ideasman42, @Sergey, @mont29
Setting the name of an image through RNA (i.e. python) forces reloading of that image (and since it does not yet exists on disc, it becomes black).
Campbell or Sergey, what do you think about adding an option to 'save' image func to specify a path?
Script-baked image gets erased when attempting to set filepathto Setting filepath of an image reloads it, which breaks all kind of generated content (including baking).Added subscriber: @dfelinto
Just to reply to your comment, not sure if it's a typo, but we talk about setting filepath, not name... although I didn't test if renaming does the same.
Yeah, sure (issue being, 'filepath' var in C struct is actually called 'name' - talking about confusing naming :/ ).
Modifying filepath will re-load the image because you might have point it to an existing file. In order to modify file path to save the image after the bake you need to use
filepath_raw
.Changed status from 'Open' to: 'Archived'
closing since this is known/intended behavior. Scripts can use
filepath_raw
.This could be called at least misleading, or very confusing behavior. The reloading is really not clear at all because it's not in documentation of the filepath prop, only mentioned in filepath_raw.... Also, what sense does it have to load an image which does not exist as a black image? shouldn't it try to load the image and when the file does not exist, then not do anything? Or, when the image path was same before, and I set the path 'to be sure' in the script, then this also has no logic at all..
But at least It's now clear to me...
Ok, so I did more tests. And, filepath_raw actually doesn't work either. It doesn't erase the image changes, but the image doesn't get saved WITH the changes... at least in the testfile I sent. I totally understand it's good to lower the number of bugs before the release, but doing it this way isn't nice to users who spend time reporting the bugs....
should I report a new one?
@VilemDuha - report a new bug is best,
However we've used both filepath(_raw) quite a lot, I would imagine if they were buggy we would have found before?.
This is how filepath_raw is intended to work:
filepath_raw
(which wont reload)Image.save
Nevertheless if you think you found a bug it would be really good to investigate before 2.74 release.
well, I just replaced filepath with filepath_raw command in the example file. i will probably test a bit more and report then.
