I see black 50%-70% of times, problem from cycles nodes. #44073
2 Participants
Reference: blender/blender#44073
win 8.1, gtx 970
blender-2.74-997c0c8-win64
I recently worked on an texture mixer .
This mixer uses internal textures like: noise, magic, wave and other simple settings(mostly math nodes).
I see black 50%-70% of times, but if i change the Mix value it can be a chance to display it normally.
However this problem appear only when i mix with the orange group node.(please see the Screenshot attached)
I cleaned the nodes overall for easy understanding, but i can't reproduce this bug in simple steps.(the nodes system can be a little hard to understand, and sorry about that)
I think the problem have a relationship with the textures, because they are connected with a math.
bug2.blend
Added subscriber: @istoltoto
Removed subscriber: @istoltoto
I used about 10 textures connected with math.
If change the value, the final texture can go from 1 to 2 to 3 to 4 and so on. (see the screenshot)
But if i remove some of the textures seems to work well.
Maybe the problem is because the Cycles not combine well if are too many textures connected.
Hi,
thanks for the report. This is not a bug, but a current limitation. If you check your terminal window, you will find the error message:
Cycles currently only supports 255 nodes per shader. This might be improved in the future, but we need to carefully check on side-effects.
You saved me with your idea!
I will use Mix shader to divide the big amount of nodes :D
thx
