Blender/System Freeze. Cycles on "Viewport Shading/Render" when Compute Device is NOT the display device. #44094
Reference: blender/blender#44094
Debian Testing. Kernel 3.19.4/4.0.0rc2
2×GPU (GTX 580/750ti)
nvidia version 346.47
2×Multiple display setup 1 monitor for each GPU.
2.72.b+dfsg0-3 (debian)
2.73a (official)
2.74 RC2 (official)
System/Compute Device/CUDA allows for selecting any or multiple supported devices.
This works fine for rendering and there appears to be no problems as multiple GPU's are utilized for rendering purposes.
However, if Viewport Shading/Render is selected and the CUDA device(s) is not the main display or multiple devices that contains a device that is not the main display device - blender will crash.
I've tested this loading blender to display from either GPU and render to the non-display GPU with no problems unless "Viewport Shading/Render" is selected then blender will freeze (without errors) and at times a system freeze (if display != :0 and I can't kill blender).
Let me know if you require any further information.
Regards.
Joules.
Any simple cycles render test.
Added subscriber: @joules-2
Added subscriber: @Sergey
I'm using mutliple videocards here on debian, and blender institute uses such a setups as well, so it'll be likely some specific setup..
Some questions:
No SLI.
Just to make it a little more concise (and it also doesn't freeze down my entire system).
GTX 580 is connected to a display.
GTX 750ti is disconnected from a display.
The following scenarios is consistent.
Blender: Works as expected.
Compute Device/CUDA/Geforce GTX 580 + 750 Ti
Render/Device/GPU Compute
(Render) F12.
Note:
When Compute Device/CUDA/Geforce GTX 580 is set (display GPU).
Viewport Shading:Render+Cycles Render [Shift+z] also works as expected.
Blender: Fails - Blender Freezes. (KILL required)
Compute Device/CUDA/Geforce GTX 580 + 750 Ti OR Geforce GTX 750 Ti
Note: The opposite is also True (750Ti connected to a display 580 not).
Let me know if you require anything else.
Heres a screenshot of the freeze screen. This is with the 750Ti as the display GPU for this monitor and the 580 disconnected from any display or xscreen. I took this while testing if the opposite situation also caused a freeze (so it can't be specific to any GPU).
Regards.
I can confirmed that disabling Vt-d (Intel ® VT for Direct I/O) within the bios resolves this bug for this particular system (Dell T7500).
Regards,
Joules.
That's an interesting observation. We could now investigate it deeper once we've got access to such hardware :)
Thanks for the information and happy blending!
Added subscriber: @edekbul
Hi,
I have similar or the same problem. I have two cards, GTX 660Ti(screen attached) and GTX 780Ti. View port is working only with 660Ti selected, any combination with 780Ti results in freeze. I have new Gigabyte GA-990FXA-UD5 motherboard and i have IOMMU setting on (same as Intel ® VTbut for AMD?). It is impossible to turn off IOMMU because all usb devices stop working with this option disabled (http://ubuntuforums.org/showthread.php?t=2143433&page=2). I need this option enabled for Xen also, so I would prefer to find workaround...
UPDATE
It turns out that it is possible to make:"GRUB_CMDLINE_LINUX="iommu=soft" in grub, and leave IOMMU option ON in Bios!. Now everything works well, USB ports, cycles, both cards in all configurations!!!:)
sudo nano /etc/default/grub
input your password
then find the line that says: GRUB_CMDLINE_LINUX=""
then make it this: GRUB_CMDLINE_LINUX="iommu=soft"
save the file
then run this in the terminal:
sudo update-grub
Can you confirm that this issue does not present itself when IOMMU is disabled in the BIOS?
When IOMMU is disabled in the BIOS my USB ports doesent work , including mouse and keyboard. I was not able to check if viewport work with IOMMU disabled. Now i have "GRUB_CMDLINE_LINUX="iommu=soft" and IOMMU enabled in bios and everything works well.
With "GRUB_CMDLINE_LINUX="iommu=soft" set and IOMMU turned off in BIOS, viewport rendering is working fine. The only scenario when viewport rendering is not working is when you dont set "GRUB_CMDLINE_LINUX="iommu=soft" and HAVE IOMMU turned in BIOS ON.
