Crash after open EXR format #44132
Closed
opened 2015-03-25 14:36:55 +01:00 by Cenek Strichel · 22 comments
W8.1 64b
Blender 2.47 RC2 and 87cff57
Rendered EXR is crashed when you try open it in Node editor.
  1. open scene:
    EXRcrash.blend
  2. render frame
  3. open rendered exr created by File Output node
  4. Crash
**System Information** W8.1 64b **Blender Version** Blender 2.47 RC2 and 87cff57 **Short description of error** Rendered EXR is crashed when you try open it in Node editor. 1) open scene: [EXRcrash.blend](https://archive.blender.org/developer/F154968/EXRcrash.blend) 2) render frame 3) open rendered exr created by File Output node 4) Crash
Author
Author
Added subscriber: @Cenda
Member
Member
Can't confirm that here, maybe it's related to your crash in #43903. Could you do the [dll ]] test again? Would also be interesting to see your [ http:*blender.stackexchange.com/a/9121 | system-info.txt .
Can't confirm that here, maybe it's related to your crash in #43903. Could you do the [dll ]] test again? Would also be interesting to see your [[ http:*blender.stackexchange.com/a/9121 | system-info.txt ](http:*download.blender.org/ftp/sergey/softwaregl/win64/opengl32.dll).
Author
It is not related to my old bug because it is now crashed on another computer, sorry I didnt add my configuration. It is Core i7, Geforce 770. I also see, that I wrote 2.47, I mean 2.74 of course :) Previous bug what you mentioned is ok on current configuration. Are you sure that you are testing exr file from File Output? not PNG from normal Output. Here is my output file:
www.cenda.cz/temp/exr.0097.exr
, which is crash after load to Node editor (to composition as Image node). I tried it load to Node editor to Material and it is working well, so problem is only in Composition Node Editor. It is also crashing with your dll.
It is not related to my old bug because it is now crashed on another computer, sorry I didnt add my configuration. It is Core i7, Geforce 770. I also see, that I wrote 2.47, I mean 2.74 of course :) Previous bug what you mentioned is ok on current configuration. Are you sure that you are testing exr file from File Output? not PNG from normal Output. Here is my output file: www.cenda.cz/temp/exr.0097.exr , which is crash after load to Node editor (to composition as Image node). I tried it load to Node editor to Material and it is working well, so problem is only in Composition Node Editor. It is also crashing with your dll. ![crash.png](https://archive.blender.org/developer/F155000/crash.png)
Member
Added subscriber: @LukasTonne
Member
Okay can confirm that now .
@LukasTonne, getting a failed assert in ImageNode::convertToOperations(...):
BLI_assert(combined_operation != NULL);
Adding a non-Null check solves the crash but I still get errors printed to the console and the image that shows up doesn't really look like I would expect it. Looks like something goes wrong during saving from the compositor?
Okay can confirm that now . @LukasTonne, getting a failed assert in ImageNode::convertToOperations(...): ``` BLI_assert(combined_operation != NULL); ``` Adding a non-Null check solves the crash but I still get errors printed to the console and the image that shows up doesn't really look like I would expect it. Looks like something goes wrong during saving from the compositor?
Lukas Tönne was assigned by Julian Eisel 2015-03-28 17:29:57 +01:00
Added subscriber: @Sergey
@JulianEisel, Lukas is the wrong guy for the compo issues. If the issue still exists please re-assign to me.
Lukas Tönne was unassigned by Julian Eisel 2015-04-14 16:03:22 +02:00
Sergey Sharybin was assigned by Julian Eisel 2015-04-14 16:03:22 +02:00
Member
Yep, it still exists.
Added subscriber: @John_Lancaster
This has been around for SEVERAL versions.
Sergey Sharybin removed their assignment 2015-04-21 10:38:49 +02:00
Dalai Felinto was assigned by Sergey Sharybin 2015-04-21 10:38:49 +02:00
Added subscriber: @dfelinto
I can't really reproduce crash in current releases, but can see the crash with current master. And there i need some inputs from @dfelinto.
Dalai, the issue is that it's a multilayer file and for some reason it does not have any views. I'm not sure if it's issue with saving the file (missing view on save) or some missing NULL pointer check on read. But i would only say here that files without views should not crash blender.
I can't really reproduce crash in current releases, but can see the crash with current master. And there i need some inputs from @dfelinto. Dalai, the issue is that it's a multilayer file and for some reason it does not have any views. I'm not sure if it's issue with saving the file (missing view on save) or some missing NULL pointer check on read. But i would only say here that files without views should not crash blender.
In Mac I did get a crash with 2.74 74df307 (aka, the commit before multiview):
BLI_assert failed: /Users/dfelinto/blender/git/blender/source/blender/compositor/nodes/COM_ImageNode.cpp:110, convertToOperations(), at 'combined_operation != __null'
- 0  0x00007fff8f922866 in __pthread_kill ()
- 1  0x00007fff8ebca35c in pthread_kill ()
- 2  0x00000001060e11b6 in abort () at date_time_facet.hpp:226
- 3  0x0000000100dca3fd in ImageNode::convertToOperations (this=0x11dde3200, converter=@0x11a328a88, context=@0x11ddbbcc0) at /Users/dfelinto/blender/git/blender/source/blender/compositor/nodes/COM_ImageNode.cpp:110
- 4  0x0000000100da3a09 in NodeOperationBuilder::convertToOperations (this=0x11a328b30, system=0x11ddbbcc0) at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_NodeOperationBuilder.cpp:68
- 5  0x0000000100d9f0d6 in ExecutionSystem::ExecutionSystem (this=0x11ddbbcc0, rd=0x10e3c3d40, scene=0x10e3c3c08, editingtree=0x11f00b498, rendering=false, fastcalculation=false, viewSettings=0x10e3c4e68, displaySettings=0x10e3c4f08) at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_ExecutionSystem.cpp:68
- 6  0x0000000100d9f417 in ExecutionSystem::ExecutionSystem (this=0x11ddbbcc0, rd=0x10e3c3d40, scene=0x10e3c3c08, editingtree=0x11f00b498, rendering=false, fastcalculation=false, viewSettings=0x10e3c4e68, displaySettings=0x10e3c4f08) at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_ExecutionSystem.cpp:104
- 7  0x0000000100d9eced in COM_execute (rd=0x10e3c3d40, scene=0x10e3c3c08, editingtree=0x11f00b498, rendering=0, viewSettings=0x10e3c4e68, displaySettings=0x10e3c4f08) at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_compositor.cpp:97
- 8  0x0000000101152753 in ntreeCompositExecTree (scene=0x10e3c3c08, ntree=0x11f00b498, rd=0x10e3c3d40, rendering=0, do_preview=1, view_settings=0x10e3c4e68, display_settings=0x10e3c4f08) at /Users/dfelinto/blender/git/blender/source/blender/nodes/composite/node_composite_tree.c:232
- 9  0x00000001001f1382 in compo_startjob (cjv=0x10e99c178, stop=0x11f01567c, do_update=0x11f01567a, progress=0x11f015680) at /Users/dfelinto/blender/git/blender/source/blender/editors/space_node/node_edit.c:241
- 10 0x0000000100146752 in do_job_thread (job_v=0x11f015608) at /Users/dfelinto/blender/git/blender/source/blender/windowmanager/intern/wm_jobs.c:328
- 11 0x00000001014bede1 in tslot_thread_start (tslot_p=0x10e9df188) at /Users/dfelinto/blender/git/blender/source/blender/blenlib/intern/threads.c:251
- 12 0x00007fff8ebc9899 in _pthread_body ()
- 13 0x00007fff8ebc972a in _pthread_start ()
#14 0x00007fff8ebcdfc9 in thread_start ()
My suspicious is that the compositor assumes to have a 'Combined' pass and the image doesnt have it (it has an Image pass instead).
Now to master: It's fine for the file to not have views, but RenderResult should always have a view. The initial crash is indeed multiview related, but it's simply masking the real problem which is likely the same as above. I can help looking at it later.
That said I should be able to help with this since I
In Mac I did get a crash with 2.74 74df307 (aka, the commit before multiview): ``` BLI_assert failed: /Users/dfelinto/blender/git/blender/source/blender/compositor/nodes/COM_ImageNode.cpp:110, convertToOperations(), at 'combined_operation != __null' - 0 0x00007fff8f922866 in __pthread_kill () - 1 0x00007fff8ebca35c in pthread_kill () - 2 0x00000001060e11b6 in abort () at date_time_facet.hpp:226 - 3 0x0000000100dca3fd in ImageNode::convertToOperations (this=0x11dde3200, converter=@0x11a328a88, context=@0x11ddbbcc0) at /Users/dfelinto/blender/git/blender/source/blender/compositor/nodes/COM_ImageNode.cpp:110 - 4 0x0000000100da3a09 in NodeOperationBuilder::convertToOperations (this=0x11a328b30, system=0x11ddbbcc0) at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_NodeOperationBuilder.cpp:68 - 5 0x0000000100d9f0d6 in ExecutionSystem::ExecutionSystem (this=0x11ddbbcc0, rd=0x10e3c3d40, scene=0x10e3c3c08, editingtree=0x11f00b498, rendering=false, fastcalculation=false, viewSettings=0x10e3c4e68, displaySettings=0x10e3c4f08) at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_ExecutionSystem.cpp:68 - 6 0x0000000100d9f417 in ExecutionSystem::ExecutionSystem (this=0x11ddbbcc0, rd=0x10e3c3d40, scene=0x10e3c3c08, editingtree=0x11f00b498, rendering=false, fastcalculation=false, viewSettings=0x10e3c4e68, displaySettings=0x10e3c4f08) at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_ExecutionSystem.cpp:104 - 7 0x0000000100d9eced in COM_execute (rd=0x10e3c3d40, scene=0x10e3c3c08, editingtree=0x11f00b498, rendering=0, viewSettings=0x10e3c4e68, displaySettings=0x10e3c4f08) at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_compositor.cpp:97 - 8 0x0000000101152753 in ntreeCompositExecTree (scene=0x10e3c3c08, ntree=0x11f00b498, rd=0x10e3c3d40, rendering=0, do_preview=1, view_settings=0x10e3c4e68, display_settings=0x10e3c4f08) at /Users/dfelinto/blender/git/blender/source/blender/nodes/composite/node_composite_tree.c:232 - 9 0x00000001001f1382 in compo_startjob (cjv=0x10e99c178, stop=0x11f01567c, do_update=0x11f01567a, progress=0x11f015680) at /Users/dfelinto/blender/git/blender/source/blender/editors/space_node/node_edit.c:241 - 10 0x0000000100146752 in do_job_thread (job_v=0x11f015608) at /Users/dfelinto/blender/git/blender/source/blender/windowmanager/intern/wm_jobs.c:328 - 11 0x00000001014bede1 in tslot_thread_start (tslot_p=0x10e9df188) at /Users/dfelinto/blender/git/blender/source/blender/blenlib/intern/threads.c:251 - 12 0x00007fff8ebc9899 in _pthread_body () - 13 0x00007fff8ebc972a in _pthread_start () #14 0x00007fff8ebcdfc9 in thread_start () ``` My suspicious is that the compositor assumes to have a 'Combined' pass and the image doesnt have it (it has an Image pass instead). Now to master: It's fine for the file to not have views, but RenderResult should always have a view. The initial crash is indeed multiview related, but it's simply masking the real problem which is likely the same as above. I can help looking at it later. That said I should be able to help with this since I
@dfelinto, I'm happy to look into compo-related issue, but for that i need multiview-related fixed first. Think it is possible to reproduce multiview-related one without touching compositor?
@Sergey in master if you hide the properties panel of the Node editor and add the Image Node with the broken EXR you get the following crash:
BLI_assert failed: /Users/dfelinto/blender/git/blender/source/blender/compositor/nodes/COM_ImageNode.cpp:128, convertToOperations(), at 'combined_operation != __null'
Program received signal SIGABRT, Aborted.
- 2  0x00007fff8d2acb1a in abort ()
- 3  0x0000000100ca5446 in ImageNode::convertToOperations (this=0x107e2ed10, converter=@0x113580a38, context=@0x107ec2c60) at /Users/dfelinto/blender/git/blender/source/blender/compositor/nodes/COM_ImageNode.cpp:128
- 4  0x0000000100c7ea29 in NodeOperationBuilder::convertToOperations (this=0x113580ae0, system=0x107ec2c60) at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_NodeOperationBuilder.cpp:68
- 5  0x0000000100c7a0d5 in ExecutionSystem::ExecutionSystem (this=0x107ec2c60, rd=0x108ab7140, scene=0x108ab7008, editingtree=0x10da57af8, rendering=false, fastcalculation=false, viewSettings=0x108ab8290, displaySettings=0x108ab8330, viewName=0x103aa7a58 "") at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_ExecutionSystem.cpp:70
- 6  0x0000000100c7a42a in ExecutionSystem::ExecutionSystem (this=0x107ec2c60, rd=0x108ab7140, scene=0x108ab7008, editingtree=0x10da57af8, rendering=false, fastcalculation=false, viewSettings=0x108ab8290, displaySettings=0x108ab8330, viewName=0x103aa7a58 "") at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_ExecutionSystem.cpp:106
- 7  0x0000000100c79cd1 in COM_execute (rd=0x108ab7140, scene=0x108ab7008, editingtree=0x10da57af8, rendering=0, viewSettings=0x108ab8290, displaySettings=0x108ab8330, viewName=0x103aa7a58 "") at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_compositor.cpp:98
- 8  0x0000000100feca03 in ntreeCompositExecTree (scene=0x108ab7008, ntree=0x10da57af8, rd=0x108ab7140, rendering=0, do_preview=1, view_settings=0x108ab8290, display_settings=0x108ab8330, view_name=0x103aa7a58 "") at /Users/dfelinto/blender/git/blender/source/blender/nodes/composite/node_composite_tree.c:233
- 9  0x00000001000ceffb in compo_startjob (cjv=0x10daacca8, stop=0x11301b4bc, do_update=0x11301b4ba, progress=0x11301b4c0) at /Users/dfelinto/blender/git/blender/source/blender/editors/space_node/node_edit.c:243
- 10 0x0000000100023a70 in do_job_thread (job_v=0x11301b448) at /Users/dfelinto/blender/git/blender/source/blender/windowmanager/intern/wm_jobs.c:328
- 11 0x0000000101334511 in tslot_thread_start (tslot_p=0x113039678) at /Users/dfelinto/blender/git/blender/source/blender/blenlib/intern/threads.c:252
Which seems to me exactly as the original error, and not related to multiview. What I propose is, you look at this compo issue, and once this is fixed I enable the property panel and fix the multiview part. There is a (high) chance that the multiview issue is gone once the main one is solved.
I can help you looking at it later, but I would rather tackle the other pending multiview problems first.
@Sergey in master if you hide the properties panel of the Node editor and add the Image Node with the broken EXR you get the following crash: ``` BLI_assert failed: /Users/dfelinto/blender/git/blender/source/blender/compositor/nodes/COM_ImageNode.cpp:128, convertToOperations(), at 'combined_operation != __null' Program received signal SIGABRT, Aborted. - 0 0x00007fff8f922866 in __pthread_kill () - 1 0x00007fff8ebca35c in pthread_kill () - 2 0x00007fff8d2acb1a in abort () - 3 0x0000000100ca5446 in ImageNode::convertToOperations (this=0x107e2ed10, converter=@0x113580a38, context=@0x107ec2c60) at /Users/dfelinto/blender/git/blender/source/blender/compositor/nodes/COM_ImageNode.cpp:128 - 4 0x0000000100c7ea29 in NodeOperationBuilder::convertToOperations (this=0x113580ae0, system=0x107ec2c60) at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_NodeOperationBuilder.cpp:68 - 5 0x0000000100c7a0d5 in ExecutionSystem::ExecutionSystem (this=0x107ec2c60, rd=0x108ab7140, scene=0x108ab7008, editingtree=0x10da57af8, rendering=false, fastcalculation=false, viewSettings=0x108ab8290, displaySettings=0x108ab8330, viewName=0x103aa7a58 "") at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_ExecutionSystem.cpp:70 - 6 0x0000000100c7a42a in ExecutionSystem::ExecutionSystem (this=0x107ec2c60, rd=0x108ab7140, scene=0x108ab7008, editingtree=0x10da57af8, rendering=false, fastcalculation=false, viewSettings=0x108ab8290, displaySettings=0x108ab8330, viewName=0x103aa7a58 "") at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_ExecutionSystem.cpp:106 - 7 0x0000000100c79cd1 in COM_execute (rd=0x108ab7140, scene=0x108ab7008, editingtree=0x10da57af8, rendering=0, viewSettings=0x108ab8290, displaySettings=0x108ab8330, viewName=0x103aa7a58 "") at /Users/dfelinto/blender/git/blender/source/blender/compositor/intern/COM_compositor.cpp:98 - 8 0x0000000100feca03 in ntreeCompositExecTree (scene=0x108ab7008, ntree=0x10da57af8, rd=0x108ab7140, rendering=0, do_preview=1, view_settings=0x108ab8290, display_settings=0x108ab8330, view_name=0x103aa7a58 "") at /Users/dfelinto/blender/git/blender/source/blender/nodes/composite/node_composite_tree.c:233 - 9 0x00000001000ceffb in compo_startjob (cjv=0x10daacca8, stop=0x11301b4bc, do_update=0x11301b4ba, progress=0x11301b4c0) at /Users/dfelinto/blender/git/blender/source/blender/editors/space_node/node_edit.c:243 - 10 0x0000000100023a70 in do_job_thread (job_v=0x11301b448) at /Users/dfelinto/blender/git/blender/source/blender/windowmanager/intern/wm_jobs.c:328 - 11 0x0000000101334511 in tslot_thread_start (tslot_p=0x113039678) at /Users/dfelinto/blender/git/blender/source/blender/blenlib/intern/threads.c:252 - 12 0x00007fff8ebc9899 in _pthread_body () - 13 0x00007fff8ebc972a in _pthread_start () #14 0x00007fff8ebcdfc9 in thread_start () ``` Which seems to me exactly as the original error, and not related to multiview. What I propose is, you look at this compo issue, and once this is fixed I enable the property panel and fix the multiview part. There is a (high) chance that the multiview issue is gone once the main one is solved. I can help you looking at it later, but I would rather tackle the other pending multiview problems first.
Dalai Felinto removed their assignment 2015-04-22 14:48:25 +02:00
Sergey Sharybin was assigned by Dalai Felinto 2015-04-22 14:48:25 +02:00
@Sergey btw, you can enable exr_printf() in openexr_api.cpp::1615 to get tons of useful debug printing.
@Sergey, commit 1076adb fixed the multiview part of this issue, now this is all yours :) but let me know if you need any help
This issue was referenced by 3de45ee7fe
This issue was referenced by 3de45ee7fe451ab4267b824a569a2173660d2575
Closed by commit 3de45ee7fe.
6 Participants
Reference: blender/blender#44132
