Normal edit rendering bug #44180
2 Participants
Reference: blender/blender#44180
Ubuntu 14.10 64bits, Nvidia GTS450 1GB
Broken: 2.74 RC4, and all the git compilations I have done since Normal edit was published.
Worked: never
The render of a mesh with subsurf and smooth is not correct. It doesn't smooth the faces in the frontier between lighted and shadowed.
In the attached blender just press F12 to see the problem.
In blender from scratch create a Suzanne, press smooth shading, activate auto smooth in the Object Data panel, add a subsurf modifier( 1 or 2 levels makes it easier to see the problem), add a normal edit modifier at the end of the stack. Render. You should see glitches in some areas. If you don't, move the light until you do.
Added subscriber: @VicenteCarro
normal-edit-bug.blend
Added subscriber: @mont29
Not quite sure about what you call glitches here… mind adding a screeshot showing them?
Here it is.
As you can see there are "flat" shaded faces in the ears even if the full mesh has "smooth shading". And the problem is per face.
Now I think this maybe happens when the change in the shading is extreme in one face (from total light to total shadow) ... or maybe not, I'm not sure.
There is no bug here. Thing is, using that normal generator on such geometry will completely invert normals of faces facing “inward”, giving that pitch black result…
