Bevel object from different scene won't automatically update generated bezier curve geometry #44213
5 Participants
Reference: blender/blender#44213
Windows 7 64bits NVidia GTX 580
Broken: Blender 2.74 RC4
Long standing bug, at least since 2.72, probably earlier
If the bevel object is in a different scene from the curve path scene it won't automatically update beveled geometry
If the bevel object is in a different scene from the curve path it won't automatically update beveled geometry
Second curve's 'B' bevel geometry is not updated, to reflect the changes in curve 'A's shape one must manually enter edit mode to force update.
Check demo file: lazy_curve_updating.blend
Curiously upon creating demo file I discovered that if the file is first opened on Scene 1, curve A is changed and Scene 2 is then opened for the first time after changing curve A's geometry, the generated mesh is correctly updated.
Added subscriber: @DuarteRamos
Added subscriber: @sindra1961
I think that the reason is the same as the following cases.
You make curve in separate layers one by one.
You set other curve in Bevel Object of one curve.
You choose only a layer of curve which you set in Bevel Object, and you edit curve.
As a result of having edited it, it is not reflected.
If you choose both layers and edit it, it is reflected.
True, I get that also in 2.72 32bits under Windows XP 64.
Now this is not a very concerning bug, just a small nuisance. It probably misses some sort of update flag or something, and this is probably done to improve performance by not updating or generating hidden geometry.
Added subscriber: @Psy-Fi
Confirmed. A dependency issue for sure. I'm not sure we support chains between scenes though.
@DuarteRamos:
I did not write that this was bug to answer in the affirmative.
I intended to show that current blender did not support the method.
Because blender is a tool, there is an assembly operation to use it.
If you want to let you reflect a change result of the Bevel object, it will be reflected if you set object again.
Hum I see, I assumed that if it updated automatically in most other situations than this was some sort of bug or missing some update flag.
If this was incorrectly assumed and this is not supported or just the expected behavior for these cases than I guess we can close the report.
@DuarteRamos:
I am not a developer of blender.
I am a user same as you.
Possibly their opinion may be different from my thing.
This issue was referenced by
2d05466700
Closed by commit
2d05466700
.Added subscriber: @Sergey
@Sergey:
I tried it in the latest edition, but nothing changes.
Is it right that what happens?
version 2.74 (sub 4), branch b'master', commit date b'2015-04-08' b'19:59', hash b'aa24704', b'Release'
I'm sorry, a way of the confirmation was wrong.
However, I have a question toward your correction.
I attach a file.
A result is reflected when I edit curve of different layer of different scene.
However, a result is not reflected even if I edit curve of different layer of same scene.
You set BezierCurve in beziel object of BezierCurve.001, and you edit it.
what.blend
Edit it without choosing layer at the same time.
Does it not ignore the setting of object>Relations>Layers?
You currently need to have both scene visible (same as in original file you submitted), otherwise layer visibility optimization will prevent flush from happening. This is being addressed in the depsgraph_refactor branch.
This comment was removed by @sindra1961
@Sergey:
My confirmation method seemed to be wrong.
I am sorry for making noise.
@Sergey:
I write only one having noticed.
I edit curve which I appointed in Bevel object, and the result is reflected by edit mode if I come back to original scene.
However, the result is not reflected when I come back to original scene after editing curve, and finishing edit mode.
It is written in the report that I come back to original scene after finishing edit mode.
Edit mode is handled differently -- it does not really need to go via depsgraph update, because edit mode is displayed directly from the DNA. But if you'll have some modifiers applied on curve and enabled for edit mode then they might be displayed incorrectly after switching layers when editing the curve.
