Manage UI Translations Crashes Blender when Rendering Hair #44216
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#44216
windows 7 64bits ; i7 ; K4000m
Broken: Blender 2.74
blender crash and closed when i render hair
Added subscriber: @seghierk
Added subscriber: @Blendify
Render Hair crashto Manage UI Translations Crashes Blender when Rendering HairAdding Bf-blender might be an issue on Blenders side
@Blendify, since the report says it works fine with the add-on disabled it's likely a bug in the add-on
Added subscriber: @mont29
Cannot reproduce that here.
@seghierk Your report is incomplete, we need a .blend file to (try to) reproduce the issue…
@JulianEisel Do not see how an addon could affect rendering… should not be possible at least. So think bf-blender is valid here.
@JulianEisel & @Blendify most important thing about a report is not its tagging, but whether it is reproducible or not, suggest you check that first of all.
i will capture video ; and i will show you another problem with hair animation
Video files are usually not much useful for us, we need to be able to reproduce the issue ourselves.
And please do not mix issues in a single report, other issue => new report.
sorry you can not reproduce the issue if i send you a file
but you to try to find what happened not only apply hair system and activate the addon
try to create scene with addon already activated than enable hair dynamic
try to render the scene ; if it rendered without problem disable the plugin than enable it and try render again
i am sure that the problem is with this addon but how i don't know and i can't give you precise steps because :
1- sometimes it work when the addon already enabled
2- if addon disabled and i enable it after adding hair system blender closed
3- sometimes blender closed when addon enabled only if i activate hair dynamics
so you must try if you don't want see the video
for the second issue right now i don't know why it happend but i will upload the scene in new report
I still cannot reproduce it even trying all kind of disable/enable of the addon… So once and for all, please attach here a file which crashes for you!
If we are not able to reproduce the issue, we cannot fix it, and we'll have to close that report…
it's not one file ; all files crash blender and sometimes colsed directly
this is the file : addon already enabled
https://www.youtube.com/watch?v=Cvw7Tyx82lI
hair_collision.blend
Still cannot reproduce here, never crashes for me… Might be specific to windows, or some other strange condition.
Set to 'Unconfirmed', if no one is able to reproduce within two weeks we’ll have to archive it.
Added subscribers: @MartijnBerger, @LukasTonne, @Psy-Fi
Martjin, maybe you can try to reproduce on ugly windows? ;)
are you see the video ?
i know that you can't find anything when i send you a scene
and you can't confirm with your try only
what happened is a big problem if you work long time than blender closed without reason
i had also problem of blue screen when i tried render hair animation with cycles.
so please don't close this report without find solution
Are you rendering on gpu or cpu. Or does it happen on both
i use cpu and i tried with gpu ;but i had the same problem
Added subscriber: @sindra1961
Have you read manual of addon?
It is written that preferences of addon is lost when I invalidate addon.
I watched a movie, but seemed to use it without setting preferences after you invalidated it to me.
When you set addon effectively, a setting item of preferences is displayed below, but do you set it?
I'm sorry, I do not try it to use addon definitely because preparations are troublesome.
Translate_Blender
Nothing new here, thanks for the report, but time to archive.
