'0'-key shortcut in 3DView (switch to/from camera view) broken - sticky keys? #44251
Closed
opened 2015-04-03 17:23:12 +02:00 by Bastien Montagne · 19 comments
NA
Broken: latest master
Animation of switching to camera view (pad0 shortcut) is now broken, a single press only partially moves the view, you have to keep it pressed (or hit it several times) to go into camera view.
Smells like timer issue? Or bad shortcut?
Just hit pad0 in 3DView of default startup file…
**System Information** NA **Blender Version** Broken: latest master Worked: (optional) **Short description of error** Animation of switching to camera view (pad0 shortcut) is now broken, a single press only partially moves the view, you have to keep it pressed (or hit it several times) to go into camera view. Smells like timer issue? Or bad shortcut? **Exact steps for others to reproduce the error** Just hit pad0 in 3DView of default startup file…
Author
Owner
Julian Eisel was assigned by Bastien Montagne 2015-04-03 17:23:12 +02:00
Author
Owner
Added subscriber: @mont29
Member
Can't recreate. Timer should not be affected by stickies, but you never know with our event system. Also I didn't touch this shortcut...
Can't recreate. Timer *should* not be affected by stickies, but you never know with our event system. Also I didn't touch this shortcut...
Author
Owner
Checked with --factory-startup, issue is still there… Do you have 'smooth view' enabled in your userpref? Can you check with factory settings?
Author
Owner
Note the same happens when switching between side/front/top views too, actually, just a bit less visible for some reason (Pad1, Pad3, etc.).
Member
Okay checked again with my Laptop and I can recreate there. And indeed it seems to be a stickies bug since turning down the Click Timeout (UserPref->Input) to 0 resolves the issue. Will have a look tomorrow.
This issue was referenced by 1604a26fe6
This issue was referenced by 1604a26fe648ba712cf2cbead2a96dbd0dab817c
Member
Member
Closed by commit 1604a26fe6.
Added subscriber: @capnm
I believe this is still not working properly. A long press
on numpad - [x], - [x], - [x] ... is causing weird effects.
It creates in total two clicks (a second one on release).
I believe this is still not working properly. A long press on numpad - [x], - [x], - [x] ... is causing weird effects. It creates in total **two clicks** (a second one on release).
Member
Changed status from 'Resolved' to: 'Open'
Member
Eeek, can confirm again and will have another look.
Member
Hrmpf, seems that this behaved a bit glitchy even before stickies were committed. Think we should just trigger the view change on key release to avoid any conflicts.
FWIIW, it seems to be also broken (in a different way) for emulated numpad keys (user preferences -> input).
The default long-press effect was (2.74):
0 - sort of fly effect
4,6,8,2 - continuous rotation +-h/v
+,- cont. zoom in/out
The default long-press effect was (2.74): 0 - sort of fly effect 4,6,8,2 - continuous rotation +-h/v +,- cont. zoom in/out
This issue was referenced by 92755da471
This issue was referenced by 92755da4712a68ed62857a1c00eb8b43916d07b6
Member
Member
Closed by commit 92755da471.
Reference: blender/blender#44251
