Cycles Image reconstruction Filter, correct sample addition, correct gamma display #44391
Reference: blender/blender#44391
1- sample addition feels not correct, I'm used to PBRT2 where samples are added like this:
but in Cycles it addes RGB to RGB, which seems not correct. "need confirmation"
2- Cycles doesn't have any image reconstruction "I was shocked!!" , when testing a simple rendering with Gaussian Filter of size 2. and size 5., it just altered how samples are created, not final image quality.
here is a good source for an image reconstruction function!
https://github.com/mmp/pbrt-v2/blob/master/src/film/image.cpp#L77-L137
3- gamma display is incorrect, test this in Cycles stand alone, --output image.jpg (will result in false gamma, and it is exactly as the displayed image in OpenGL buffer in Blender or in Cycles) , and --output image.exr (will result in correct gamma)
Added subscriber: @MohamedSakr-2
Added subscriber: @Blendify
Ehh, sounds to me this is a set of todos, but no real bugs? Changing to todo for now
well I consider (1) as a bug because it adds wrong values "if I'm correct" , they should be added in XYZ color space (not RGB)
about (2) it is misleading for the user, user expects an antialiasing filter, here it doesn't do any reconstruction
about (3) again it is for the "correct" color viewing during render, so user doesn't add light to dark areas "while they are not black if they got gamma correction"
Will reply on each of the points:
So thanks for the report, but such reports does not really belong to here.
Hey Sergey,
1- you are correct, that's why I needed a confirmation :) as I wasn't sure, but I guess implementing a Spectrum class and giving the user an option to choose between Spectrum and RGB is very good "this is needed before extending Cycles with photons, Caustics, etc.."
2- I disagree at this point, imagine an image which needs 1000 spp to converge in animation, it may need only 500 spp to converge in animation with image reconstruction.
3- the issue is in both standalone and in Blender, I confirmed it with a friend "and by tests" , saving image to OpenEXR saves it with correct gamma "2.2" or to be exact "as written in Cycles"
1.055f * powf(c, 1.0f / 2.4f) - 0.055f;
so if .exr -> bright image with correct feedback (only in save, not in preview buffer)
else -> dark image (similar to preview).
I didn't tell that image reconstruction does not help, i was only telling that in blender it's not necesserily belong to render engine. Plus, it's not a magic bullet either, it wouldn't help you much with effects like DOF and motion blur.
Gamma 2.2 is not correct for exr files, they're expected to be in linear scene space. What are the steps of reproducing the exr file which is not in linear space from blender?
I can't reproduce it from blender, the saved image is exactly = to the previewed image "in any format" , both appear with linear gamma which gives the user wrong impression "at least when he tries to render in progressive mode to test lights and shaders"
in standalone, OpenEXR gamma get changed "corrected", but .jpg for example gives the same impression as preview.
First you say that it happens in blender then you say you can't reproduce it in blender. That's confusing.
So if there's something wrong in blender itself, which exact steps you're doing, what you're expecting and what results you're having?
sorry for this, my first test was inside blender "no images saved" , and images were the same, thought it would make the same problem after saving "like in Cycles Standalone" , but the save mechanism is different in Blender and Cycles Standalone.
so the problem is ONLY in the Standalone.
