Make Dupli-Face function translate objects #44510
Reference: blender/blender#44510
Win7
Broken: 2.74
Sometime, object are moved when using "make dupli-face" operator
Open attached file, call "make dupli-face" operator, object in the middle of the right window disappear.
bug_make_dupliface_v2.blend
Added subscriber: @bliblubli
*left window not right, sorry.
Added subscriber: @sindra1961
All of them are the same instance.
Therefore it was gathered by one.
The phenomenon that you reported can be realized by the following methods.
1.You produce the object.
2.You choose it and carry out make dupli-faces.
3.You choose generated dupli-object and carry out make dupli-faces again.
Very small plane is generated in the place that reflects original instance when make dupli-faces is carried out.
If you choose one in your attached file and carry out Cursor to selected, a cursor should move to the substance of the item which you chose.
If you make zooming in there carefully, very small plane should be found.
I do not know how you made the file, but think that probably it works definitely.
I attach a file.
This is near to the situation that you showed, but this acts definitely.
untitled.blend
There is no bug here, you are merely suffering from precision issues (you know, floats…) - your objects (curves) have extreme offsets (like -500 for median point of a curve's control points in local space), this generates small errors that add up to give imprecise 'conversion' from mere objects to dupli ones. Thanks for the report, but nothing we can do here.
I didn't create that file. The extreme offset comes then from the official DXF Importer I used. So maybe the bug report should be done their ?
