install_deps.sh fails with llvm not found (however llvm3.4 is compiled earlier) #44540
Closed
opened 2015-04-28 21:12:14 +02:00 by Piotr Arłukowicz · 10 comments
Linux Mint 17.1, updated, Tesla2070
Broken: last master origin
0. Fresh Linux Mint 17.1 install.
  1. Updated system.
  2. Installed git and build-essential
  3. Cloned blender with git clone http://git.blender.org/blender.git
  4. From ~/bin/blender-git/blender run build_files/build_environment/install_deps.sh with options: --with-all -s ~/bin/blender-git/depssrc -i ~/bin/blender-git/deps
  5. After the compilation of few components, script failed with error describe below.
HEAD is now at 22ee5ea Workaround to make OSl compilable with older OIIO library
ILMBASE_HOME=/home/piotao/bin/blender-git/deps/openexr
  • The C compiler identification is GNU 4.8.2
  • The CXX compiler identification is GNU 4.8.2
  • Check for working C compiler: /usr/bin/cc
  • Check for working C compiler: /usr/bin/cc -- works
  • Detecting C compiler ABI info
  • Detecting C compiler ABI info - done
  • Check for working CXX compiler: /usr/bin/c++
  • Check for working CXX compiler: /usr/bin/c++ -- works
  • Detecting CXX compiler ABI info
  • Detecting CXX compiler ABI info - done
  • Project source dir = /home/piotao/bin/blender-git/depssrc/OpenShadingLanguage-1.5.11
  • Project build dir = /home/piotao/bin/blender-git/depssrc/OpenShadingLanguage-1.5.11/build
  • Using gcc 4.8 as the compiler
  • CMAKE_CXX_COMPILER is /usr/bin/c++
  • CMAKE_CXX_COMPILER_ID is GNU
  • platform = linux64
  • OPENIMAGEIOHOME = /home/piotao/bin/blender-git/deps/oiio
  • #define ILMBASE_VERSION_STRING "2.2.0"
  • Looking for include file pthread.h
  • Looking for include file pthread.h - found
  • Looking for pthread_create
  • Looking for pthread_create - not found
  • Looking for pthread_create in pthreads
  • Looking for pthread_create in pthreads - not found
  • Looking for pthread_create in pthread - found
  • Found Threads: TRUE
  • Found IlmBase: /home/piotao/bin/blender-git/deps/openexr/include
  • BOOST_ROOT
  • Boost version: 1.54.0
  • Found the following Boost libraries:
  • filesystem
  • regex
  • system
  • thread
  • Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found version "1.2.8")
  • Partio not found
  • LLVM version =
  • LLVM dir =
    CMake Error at src/cmake/externalpackages.cmake:229 (message):
LLVM not found.
Call Stack (most recent call first):
CMakeLists.txt:200 (include)
  • Configuring incomplete, errors occurred!
    See also "/home/piotao/bin/blender-git/depssrc/OpenShadingLanguage-1.5.11/build/CMakeFiles/CMakeOutput.log".
    See also "/home/piotao/bin/blender-git/depssrc/OpenShadingLanguage-1.5.11/build/CMakeFiles/CMakeError.log".
    make: *** No targets specified and no makefile found. Stop.
    make: *** No rule to make target `clean'. Stop.
    ERROR! OpenShadingLanguage-1.5.11 failed to compile, exiting
HOWEVER!
There is LLVM already compiled in:
/home/piotao/bin/blender-git/deps:
pio@maon|~/bin/blender-git/blender> /bin/ls -gG ../deps
razem 24
lrwxrwxrwx 1 42 kwi 28 19:27 llvm -> /home/piotao/bin/blender-git/deps/llvm-3.4
drwxr-xr-x 6 4096 kwi 28 19:27 llvm-3.4
drwxr-xr-x 4 4096 kwi 28 19:10 numpy-1.8.1
lrwxrwxrwx 1 44 kwi 28 19:11 ocio -> /home/piotao/bin/blender-git/deps/ocio-1.0.9
drwxr-xr-x 5 4096 kwi 28 19:11 ocio-1.0.9
lrwxrwxrwx 1 45 kwi 28 19:14 oiio -> /home/piotao/bin/blender-git/deps/oiio-1.4.16
drwxr-xr-x 5 4096 kwi 28 19:14 oiio-1.4.16
lrwxrwxrwx 1 47 kwi 28 19:12 openexr -> /home/piotao/bin/blender-git/deps/openexr-2.2.0
drwxr-xr-x 6 4096 kwi 28 19:12 openexr-2.2.0
lrwxrwxrwx 1 46 kwi 28 19:06 python-3.4 -> /home/piotao/bin/blender-git/deps/python-3.4.0
drwxr-xr-x 6 4096 kwi 28 19:06 python-3.4.0
exact LLVM dir:
pio@maon|~/bin/blender-git/blender> tree -d ../deps/llvm
../deps/llvm
├── bin
├── include
│ ├── clang
│ │ ├── Analysis
│ │ │ ├── Analyses
│ │ │ ├── DomainSpecific
│ │ │ ├── FlowSensitive
│ │ │ └── Support
│ │ ├── ARCMigrate
│ │ ├── AST
│ │ ├── ASTMatchers
│ │ │ └── Dynamic
│ │ ├── Basic
│ │ ├── CodeGen
│ │ ├── Config
│ │ ├── Driver
│ │ ├── Edit
│ │ ├── Format
│ │ ├── Frontend
│ │ ├── FrontendTool
│ │ ├── IDE
│ │ ├── Index
│ │ ├── Lex
│ │ ├── Parse
│ │ ├── Rewrite
│ │ │ ├── Core
│ │ │ └── Frontend
│ │ ├── Sema
│ │ ├── Serialization
│ │ ├── StaticAnalyzer
│ │ │ ├── Checkers
│ │ │ ├── Core
│ │ │ │ ├── BugReporter
│ │ │ │ └── PathSensitive
│ │ │ └── Frontend
│ │ └── Tooling
│ ├── clang-c
│ ├── llvm
│ │ ├── ADT
│ │ ├── Analysis
│ │ ├── Assembly
│ │ ├── Bitcode
│ │ ├── CodeGen
│ │ │ └── PBQP
│ │ │ └── Heuristics
│ │ ├── Config
│ │ ├── DebugInfo
│ │ ├── ExecutionEngine
│ │ ├── IR
│ │ ├── IRReader
│ │ ├── LTO
│ │ ├── MC
│ │ │ └── MCParser
│ │ ├── Object
│ │ ├── Option
│ │ ├── Support
│ │ ├── TableGen
│ │ ├── Target
│ │ └── Transforms
│ │ ├── IPO
│ │ └── Utils
│ └── llvm-c
│ └── Transforms
├── lib
│ └── clang
│ └── 3.4
│ └── include
└── share
  ├── clang
  └── llvm
      └── cmake
71 directories
**System Information** Linux Mint 17.1, updated, Tesla2070 **Blender Version** Broken: last master origin **Short description of error** 0. Fresh Linux Mint 17.1 install. 1. Updated system. 2. Installed git and build-essential 3. Cloned blender with git clone http://git.blender.org/blender.git 4. From ~/bin/blender-git/blender run build_files/build_environment/install_deps.sh with options: --with-all -s ~/bin/blender-git/depssrc -i ~/bin/blender-git/deps 5. After the compilation of few components, script failed with error describe below. [...] HEAD is now at 22ee5ea Workaround to make OSl compilable with older OIIO library ILMBASE_HOME=/home/piotao/bin/blender-git/deps/openexr - The C compiler identification is GNU 4.8.2 - The CXX compiler identification is GNU 4.8.2 - Check for working C compiler: /usr/bin/cc - Check for working C compiler: /usr/bin/cc -- works - Detecting C compiler ABI info - Detecting C compiler ABI info - done - Check for working CXX compiler: /usr/bin/c++ - Check for working CXX compiler: /usr/bin/c++ -- works - Detecting CXX compiler ABI info - Detecting CXX compiler ABI info - done - Project source dir = /home/piotao/bin/blender-git/depssrc/OpenShadingLanguage-1.5.11 - Project build dir = /home/piotao/bin/blender-git/depssrc/OpenShadingLanguage-1.5.11/build - Using gcc 4.8 as the compiler - CMAKE_CXX_COMPILER is /usr/bin/c++ - CMAKE_CXX_COMPILER_ID is GNU - platform = linux64 - OPENIMAGEIOHOME = /home/piotao/bin/blender-git/deps/oiio - #define ILMBASE_VERSION_STRING "2.2.0" - Looking for include file pthread.h - Looking for include file pthread.h - found - Looking for pthread_create - Looking for pthread_create - not found - Looking for pthread_create in pthreads - Looking for pthread_create in pthreads - not found - Looking for pthread_create in pthread - Looking for pthread_create in pthread - found - Found Threads: TRUE - Found IlmBase: /home/piotao/bin/blender-git/deps/openexr/include - BOOST_ROOT - Boost version: 1.54.0 - Found the following Boost libraries: - filesystem - regex - system - thread - Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found version "1.2.8") - Partio not found - LLVM version = - LLVM dir = CMake Error at src/cmake/externalpackages.cmake:229 (message): ``` LLVM not found. ``` Call Stack (most recent call first): ``` CMakeLists.txt:200 (include) ``` - Configuring incomplete, errors occurred! See also "/home/piotao/bin/blender-git/depssrc/OpenShadingLanguage-1.5.11/build/CMakeFiles/CMakeOutput.log". See also "/home/piotao/bin/blender-git/depssrc/OpenShadingLanguage-1.5.11/build/CMakeFiles/CMakeError.log". make: *** No targets specified and no makefile found. Stop. make: *** No rule to make target `clean'. Stop. ERROR! OpenShadingLanguage-1.5.11 failed to compile, exiting HOWEVER! There is LLVM already compiled in: /home/piotao/bin/blender-git/deps: pio@maon|~/bin/blender-git/blender> /bin/ls -gG ../deps razem 24 lrwxrwxrwx 1 42 kwi 28 19:27 llvm -> /home/piotao/bin/blender-git/deps/llvm-3.4 drwxr-xr-x 6 4096 kwi 28 19:27 llvm-3.4 drwxr-xr-x 4 4096 kwi 28 19:10 numpy-1.8.1 lrwxrwxrwx 1 44 kwi 28 19:11 ocio -> /home/piotao/bin/blender-git/deps/ocio-1.0.9 drwxr-xr-x 5 4096 kwi 28 19:11 ocio-1.0.9 lrwxrwxrwx 1 45 kwi 28 19:14 oiio -> /home/piotao/bin/blender-git/deps/oiio-1.4.16 drwxr-xr-x 5 4096 kwi 28 19:14 oiio-1.4.16 lrwxrwxrwx 1 47 kwi 28 19:12 openexr -> /home/piotao/bin/blender-git/deps/openexr-2.2.0 drwxr-xr-x 6 4096 kwi 28 19:12 openexr-2.2.0 lrwxrwxrwx 1 46 kwi 28 19:06 python-3.4 -> /home/piotao/bin/blender-git/deps/python-3.4.0 drwxr-xr-x 6 4096 kwi 28 19:06 python-3.4.0 exact LLVM dir: pio@maon|~/bin/blender-git/blender> tree -d ../deps/llvm ../deps/llvm ├── bin ├── include │ ├── clang │ │ ├── Analysis │ │ │ ├── Analyses │ │ │ ├── DomainSpecific │ │ │ ├── FlowSensitive │ │ │ └── Support │ │ ├── ARCMigrate │ │ ├── AST │ │ ├── ASTMatchers │ │ │ └── Dynamic │ │ ├── Basic │ │ ├── CodeGen │ │ ├── Config │ │ ├── Driver │ │ ├── Edit │ │ ├── Format │ │ ├── Frontend │ │ ├── FrontendTool │ │ ├── IDE │ │ ├── Index │ │ ├── Lex │ │ ├── Parse │ │ ├── Rewrite │ │ │ ├── Core │ │ │ └── Frontend │ │ ├── Sema │ │ ├── Serialization │ │ ├── StaticAnalyzer │ │ │ ├── Checkers │ │ │ ├── Core │ │ │ │ ├── BugReporter │ │ │ │ └── PathSensitive │ │ │ └── Frontend │ │ └── Tooling │ ├── clang-c │ ├── llvm │ │ ├── ADT │ │ ├── Analysis │ │ ├── Assembly │ │ ├── Bitcode │ │ ├── CodeGen │ │ │ └── PBQP │ │ │ └── Heuristics │ │ ├── Config │ │ ├── DebugInfo │ │ ├── ExecutionEngine │ │ ├── IR │ │ ├── IRReader │ │ ├── LTO │ │ ├── MC │ │ │ └── MCParser │ │ ├── Object │ │ ├── Option │ │ ├── Support │ │ ├── TableGen │ │ ├── Target │ │ └── Transforms │ │ ├── IPO │ │ └── Utils │ └── llvm-c │ └── Transforms ├── lib │ └── clang │ └── 3.4 │ └── include └── share ``` ├── clang └── llvm └── cmake ``` 71 directories
Author
Member
Author
Member
Added subscriber: @piotao
Added subscriber: @mont29
You should not have to build llvm at all, mint17 is based on Ubuntu Trusty, which have llvm 3.4 packages…
Anyway, I would need the full logs of a clean install_deps.sh run to investigate this (please attach it as a file, instead of pasting it like that directly in report), as well as the two files mentionned here:
You should not have to build llvm at all, mint17 is based on Ubuntu Trusty, which have llvm 3.4 packages… Anyway, I would need the full logs of a clean install_deps.sh run to investigate this (please attach it as a file, instead of pasting it like that directly in report), as well as the two files mentionned here: > See also "/home/piotao/bin/blender-git/depssrc/OpenShadingLanguage-1.5.11/build/CMakeFiles/CMakeOutput.log". > See also "/home/piotao/bin/blender-git/depssrc/OpenShadingLanguage-1.5.11/build/CMakeFiles/CMakeError.log".
Author
Member
Dear Bastien, thank you for reply.
I'll prepare fresh install again in few days, and include required files as you requested. Sorry for inconvenience.
Also, I'm using Mint Distro, which is based on Debian, not on Ubuntu, and in standard distro there is only llvm-3.3 included as packages. However, this is still 17.1 quiana release.
cheers
pio
Dear Bastien, thank you for reply. I'll prepare fresh install again in few days, and include required files as you requested. Sorry for inconvenience. Also, I'm using Mint Distro, which is based on Debian, not on Ubuntu, and in standard distro there is only llvm-3.3 included as packages. However, this is still 17.1 quiana release. cheers pio
Afaik, mint 17.1 is Rebecca and is based on Trusty (http:*www.linuxmint.com/download_all.php), which has llvm 3.4 in its repo (http:*packages.ubuntu.com/search?keywords=llvm&searchon=names&suite=trusty&section=all) …
Author
Member
So... you're right!
Here's my linux version, however:
Linux maon.* 3.11-2-amd64 #1 SMP Debian 3.11.8-1 (2013-11-13) x86_64
Last login: Wed Apr 29 20:22:16 2015 from hebron
pio@maon|~> cat /etc/lsb-release
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=1
DISTRIB_CODENAME=debian
DISTRIB_DESCRIPTION="LMDE MATE Edition"
pio@maon|~> apt-cache search llvm- dev --names-only
libghc-llvm-dev - Haskell bindings to the LLVM compiler toolkit
libghc-llvm-base-dev - low-level bindings to the LLVM compiler toolkit
libllvm-ocaml-dev - Low-Level Virtual Machine (LLVM), bindings for OCaml
llvm-dev - Low-Level Virtual Machine (LLVM), libraries and headers
libllvm-3.2-ocaml-dev - Low-Level Virtual Machine (LLVM), bindings for OCaml
llvm-3.2-dev - Low-Level Virtual Machine (LLVM), libraries and headers
libllvm-3.3-ocaml-dev - Modular compiler and toolchain technologies, OCaml bindings
llvm-3.3-dev - Modular compiler and toolchain technologies, libraries and headers
pio@maon|~>
So, it seems that my distro, based on Debian, is not the same as 17.1. Strange! I don't remember when I downloaded my install CD (maybe it was some earlier test version?), but that obviously is not the last one. Thank you, I'll check Rebecca and then the whole problem can disappear!
So... you're right! Here's my linux version, however: Linux maon.* 3.11-2-amd64 #1 SMP Debian 3.11.8-1 (2013-11-13) x86_64 Last login: Wed Apr 29 20:22:16 2015 from hebron pio@maon|~> cat /etc/lsb-release DISTRIB_ID=LinuxMint DISTRIB_RELEASE=1 DISTRIB_CODENAME=debian DISTRIB_DESCRIPTION="LMDE MATE Edition" pio@maon|~> apt-cache search llvm- dev --names-only libghc-llvm-dev - Haskell bindings to the LLVM compiler toolkit libghc-llvm-base-dev - low-level bindings to the LLVM compiler toolkit libllvm-ocaml-dev - Low-Level Virtual Machine (LLVM), bindings for OCaml llvm-dev - Low-Level Virtual Machine (LLVM), libraries and headers libllvm-3.2-ocaml-dev - Low-Level Virtual Machine (LLVM), bindings for OCaml llvm-3.2-dev - Low-Level Virtual Machine (LLVM), libraries and headers libllvm-3.3-ocaml-dev - Modular compiler and toolchain technologies, OCaml bindings llvm-3.3-dev - Modular compiler and toolchain technologies, libraries and headers pio@maon|~> So, it seems that my distro, based on Debian, is not the same as 17.1. Strange! I don't remember when I downloaded my install CD (maybe it was some earlier test version?), but that obviously is not the last one. Thank you, I'll check Rebecca and then the whole problem can disappear!
Bastien Montagne self-assigned this 2015-05-06 10:01:52 +02:00
Eeeeh, this was still open, time to archive!
Author
Member
Yes, you can close it, please.
2 Participants
Reference: blender/blender-addons#44540
