Merge Collapse tool - UVs operator panel option ignored with Collapse but not with other merge types #44560
Reference: blender/blender#44560
Fedora Linux 21 64bit IvyBridge
Broken: (example: 2.69.7
4b206af
, see splash screen)Worked: (optional)
I am using Blender 2.74 "4288ab1" Release Build on a 64Bit Linux Fedora box.
I noticed that when using the ALT+M Merge tool that the Uvs option that is displayed
in the Operator Panel does not seem to work when used with the
Collapse Merge Type. The Uvs option does work with the other Merge Types.
I have included a blend file which has a grid that has a UV mapped image
on it.
If I merge a 4x4 square of vertices on the grid with alt+M and select
center and select the Uvs option the Uvs move position as expected, and
if UVs is not selected the UVs dont move (as expected).
But if I select exactly the same vertices are use collapse the UVs
move position even if the UVs operator panel option is not selected.
As far as I can tell using either Collapse or Center should result
in identical behaviour when a single square region of vertices are
merged.
See attached video for a demo.
Also included are my system-info.txt file
system-info.txt
CollapseUvsIgnored.webm
Merge_UV_Test.blend
Added subscriber: @TerryWallwork-1
Added subscriber: @mont29
Yes, collapse uses different code internally, which always does the UV work. Will fix.
This issue was referenced by
74d31279cd
Closed by commit
74d31279cd
