Assigning mesh data to object with skin modifier doesn't update skin_vertices data layer
W7 - 74 + GTX 970 (full system info:
Broken: 2.74 release (for windows 64) hash 000dfc0
Worked: don't know (haven't any old versions on hand that support skin modifier)
When assigning different mesh data to an object that has a skin modifier attached, the skin modifier fails, that is it does not show a skinned mesh.
When examining the mesh data layers for the active object the skin_vertices datalayers are gone
(see attached .blend)
  • Select the Cube object
  • In the Object data tab: assign the Mesh data from the Icosphere
  • Observe failure (mesh is replaced by linked data, but no skinning is done)
In the Python console type:
C.active_object.data.skin_vertices[0]
an error is printed:
IndexError: bpy_prop_collection[index]: index 0 out of range, size 0
Michel Anders (varkenvarken) created this task.
Michel Anders (varkenvarken) raised the priority of this task from to Needs Triage by Developer.
Bastien Montagne (mont29) triaged this task as Normal priority.
Yeah, there's too much ways to get this 'missing skin data' situation… we need a fallback manual 'add skin' button here.
Added a button to manually add skin data in cases like those, in the modifier UI - we just cannot keep track of all possible ways to end up in this situation!
