Offsetting image sequence with driver on displace modifier texture does not work. #44622
2 Participants
Reference: blender/blender#44622
CPU i7 4930k 3.40GHz
RAM 32Gb
Windows 8.1pro 64bit Nvidia GTX 780i
Broken: 2.74
000dfc0
Offsetting image sequence with driver on displace modifier texture does not work. ( driver is generated but doesn't work)
We need this to animate growing veins on character.
We are uploading blend file, however image sequences cannot be packed. Driver in blend file is set but with empty sequence.
Added subscriber: @DiegoSG
Added subscriber: @mont29
Missing .blend file so far…
Anyway, this is most likely a limitation of depsgraph, would need the file to be sure though.
Did you try to enable extra object/obdata updates of your objects (Object buttons, Relations Extra panel)? This (bad) hack can fix some issues of that kind sometimes.
Here it is, I first sent it through mail, sorry about that.
Displace_driver.blend
Hmmm… OK, I think this is current depsgraph limitation - modifiers are not well supported here… Workaround: remove your driver, add a dummy material, assign to it same exact texture, add driver to this 'usecase' of the texture. Should work, and since it's the same datablock, driver will affect modifier texture as well.
Will close as known limitation of current code, hopefully this shall be fixed with incoming new depsgraph. Thanks for the report anyway.
Thanks , works perfect!!!!
