Texture Paint float buffer: 1. Alpha problem at edge 2. Painting glitch
Win 7, GTX 560ti
Win 8, GTX 980
Broken: 2.74 release
Worked: not sure
When float buffer on
  1. Repaint an image with alpha locked, result in the semi transparent edges to glow
note: Alpha on/off as in the UI (not alpha lock ON/OFF)
  1. With the same setting, if you select another hue for the repaint (alpha locked), glitch color will be produced
Note: Please turn off Alpha lock (meaning tick alpha)
For alpha edge problem:
  1. Paint with the brush,
  2. turn on alpha lock,
  3. repaint with the same color,
  4. observe the edges
For the color glitch:
  3. repaint with another hue,
  4. Glitch may appear, if not, try another color.
Thanks in advance.
