Autocalibration may be fixing the sign of eigenvalues incorrectly #44664
6 Participants
Reference: blender/libmv#44664
Originally from: https://code.google.com/p/libmv/issues/detail?id=32#makechanges
What steps will reproduce the problem?
Reference:
After execution of these lines, I am still finding negative eigen values in temp_values.
What is the expected output? What do you see instead?
If I am not wrong, this should code should replaced with the code given below to ensure non-negative eigen values:
Added subscriber: @Keir
Added subscriber: @mont29
Added subscriber: @Sergey
Added subscriber: @dr.sybren
I'm tempted to close this task, as there is no description of what error occurs or how to reproduce it. @Keir, @Sergey, is this still a change that should be applied?
Changed status from 'Confirmed' to: 'Needs User Info'
Added subscriber: @AdamKalisz
This comment was removed by @AdamKalisz
