multiple object editing bug if alt is pressed after first edits #44706
Reference: blender/blender#44706
Win7x64
Broken:
434086d
If Alt is pressed while changing the values with mouse dragging, it gives unexpected behaviors
Default scene, duplicate the cube and select both.
Start to edit the scale in N panel by dragging the mouse, then press alt while dragging.
One of the cube get very fast randoms scaling.
Expected behavior when pressing alt: The rest of the selection gets the same changes as the active one ?
Added subscriber: @bliblubli
Added subscriber: @zeauro
I can confirm the bug under ubuntu 14.04 64bits hash
8bf9e14
.I have no problem if I reproduce step for one value of array.
In this case, alt pressed after start of editing is ignored.
But if I use L multi-editing to scale 2 or 3 values of the array, bug is obvious.
Unactive object of selection grows faster and only in 1 or 2 axis.
Problem is the same for other transformations, delta transformations, array modifier.. (3 axis numeric field).
L multi-editing on one object seems to be broken, too.
For dimensions array, when 2 values are increased, only 1 axe is modified.
When 3 values are increased, scale is only on 2 axes.
Added subscriber: @mont29
Fixed
662746fdd4
