fbx export shapekeys #44710
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#44710
MS Windows 7, Geforce GTX 690
Broken: 2.74
lips mouth ``are missing
, while blendshapes for eyebrows, tongue, teeth are thereBased on a (as simple as possible) attached .blend file with minimum amount of steps
Cannot upload file due to size constraints (simplified still 8 MB zipped)
Added subscriber: @Pitrs
That kind of issue should be easy to reproduce with a much simpler case, I cannot work on FBX with complex files anyways. Please attach here a simple, reproducible case of the issue (and please also first check it’s still valid with a build from our buildbot).
ShapeKeysTest.blend
Hi Bastien,
here comes the .blend file......
Greetings
Peter
Hi Bastien,
tried the nighly build,
but still the same result: shapekeys of the "face"-mesh are not exported.
Greetings
Peter
Here all skeys from the face ('body' mesh) are missing after export/reimport in blender… But those look broken to me, just small slider-value other than zero give huge, ugly deformations.
Tong, eyebrow etc. looks OK. Will check further tomorrow on this, too.
OK, so not bug here actually. There are two things to know when intending to export skeys:
Hi Bastien, you are right: tried it with Export modifiers unchecked, works fine :)
Thanks a lot
Peter
